Why is the length of a QR code fixed?
  • Topic:
  • Thread starter Albert1
    Code Length
Albert1
prove the length of QR is fixed
  • Geometry diagram of a circle with centre O and dashed red outline. Points A, P and B lie on the arc, with P perpendicular foot segments PQ to AO and PR to BO, forming quadrilateral OQPR with right angles at Q and R.
I assume that $A$, $B$ and $O$ are meant to be fixed, but that $P$ varies, and the aim is to show that the length $QR$ is independent of the position of $P$.
[sp]
Let $C$ be the midpoint of $OP$, let $r$ be the radius of the circle, and let $\alpha$ be the angle $AOB$. The circle with centre at $C$ and diameter $OP$ has radius $\frac12r$ and passes through $Q$ and $R$ (because of the right angles). The angle $QCR$ is $2\alpha$. By dropping a perpendicular from $C$ to $QR$, you see that $QR = 2CR\sin\alpha = r\sin\alpha.$ That depends only on $r$ and $\alpha$ and so is independent of the position of $P$.[/sp]
  • Geometry diagram: dashed circle centered at O with points A, P and B on its arc, and segments PQ perpendicular to AO and PR perpendicular to BO, forming a point C at the midpoint of OP and segment QR.
