- 2,231
neopolitan,
It's true that the caesium 133 radiation has a wavelength, but the point is that you don't need to have measured that wavelength in order to define a second. You could define your unit of length to be anything at all you liked but the second's definition would still be valid and unaltered.
In fact, you could define a metre to be 299792458/9192631770 wavelengths of caesium 133 radiation, and in some ways that would be a better definition because all you have to do is count wavelengths without needing to have a definition of time-units. This would make length "independent" of time in terms of its definition considered in isolation. Of course, considering this definition of distance and the definition of time simultaneously shows the two are linked, but logically you can arbitrarily choose either one to be independent and then the other becomes dependent.
To put it another way, you have one degree of freedom in choosing how to measure either time or distance, but once you've made that choice then the method of the other measurement is effectively fixed apart from a conversion factor c.
The spacetime view is that time and space are just different dimensions of a unified structure and c is just the conversion factor that links the two together.
