Why is the triangle edge length Rθ in circular motion?
  • Thread starter MienTommy
    Length
7 replies · 2K views · last reply
MienTommy
Diagram (b) of a rectangular block resting tilted on a semicircular cylinder of radius R, with angle θ marked, weight W = mg acting down, labels Rθ, Rθ sin θ, h/2, (R + h/2) cos θ, height y and a datum line.
That's the image. I can't see how the edge of that middle triangle's length is Rθ at all. I've tried using similar triangles and law of cosines to figure that out but I'm missing lengths. I thought Rθ was the arc length of a piece of a circle? So if Rθ is a length of a piece of a circle, how is Rθ equal to that edge of the triangle?
  • Diagram (b) of a rectangular block resting tilted at angle θ on a half-cylinder of radius R, with W = mg acting down at its centre, labelled Rθ, Rθ sin θ, h/2, (R + h/2) cos θ, y and Datum.
It looks to me like this is a "given." You might be seeing right angles where none exist.
Took me a few moments to figure it out. The answer is that the block started off horizontal then rocks to the left without slipping on the cylinder ... so the red and green lines in this version must be the same length...
Free-body diagram of a rectangular block resting tilted on a cylinder of radius R, with angle theta marked, weight W = mg acting down at the centre, labels R theta, R theta sin theta, h/2, (R + h/2) cos theta, y and Datum.
But your green line doesn't equal R*theta as labeled, right?
I.e., the extension of the radius R to the mid-point line of the bar is not parallel to the line from the top of the cylinder to the big black dot.
I had another think about this. I think you are right. I think the bit in yellow should have been omitted.
Diagram of a block of height h resting tilted at angle theta on a circular cylinder of radius R, with weight W = mg acting downward, labelled R theta, R theta sin theta, (R + h/2) cos theta, height y above a datum line, and angle theta marked at the centre.
It becomes obvious something is wrong when theta is 90 degrees.
Bingo; that was my "aha" moment also.
