Why does the relative velocity angle equal the other angle in this vector triangle?
  • Thread starter Thread starter elementG
    Angle Degrees
7 replies · 2K views
elementG
Problem #199
http://img88.imageshack.us/img88/8008/scan0001vd.jpg
Solution
http://img21.imageshack.us/img21/2131/199hg.jpg
Why is the angle from VB/A 20 degrees from the solution diagram? It would seem that I had to know that direction of VB/A had the same angle as VA in terms of the geometry (if two parallel lines are cut by a transversal, its alternating interior angles are equal). I just don't see how you can assume that.
Since drawing a triangle is the first part, I don't have any "attempt" at it yet.
I'm not sure what you're asking.
You are given that the bearing is 20 degrees. i.e. A takes a bearing of B and sees it is 20 degrees East of North, thus theta is 20 degrees.
I saw that 20 degrees was given, I just don't see how the angle is 20 degrees on the solution diagram. Ship A observes ship B at 20 degrees, but how is VB/A also 20 degrees down from horizontal? Sorry for the confusion!
It's been while, sorry, VB/A represents what part of the diagram?
I'd assumed we only care about angle theta, which is 20.
VB/A comes off the head of VA. I just don't see how its 20 degrees when VB/A and VA are connected as seen on the solutions diagram.
Sorry, I hadn't looked at the second diagram.
Well, the solution triangle is just a rearrangement of the starting configuration. The two vectors start off at 20 degrees, why would that change?
Oh, I guess I made the wrong assumption. I was assuming the angle that VB/A made was not necessarily 20 degrees. I guess I'm confused (a little bit) still is because I can't see it geometrically. Like say for instance, I'm still on the assumption that the angle is not 20 degrees for VB/A and I label as an unknown, how would I geometrically prove that the angle is 20 degrees?
You would not be able to solve the problem. You're given the angle because you need it.
