Why is this matrix not working in my program?
9 replies · 2K views · last reply
etotheipi
https://projecteuler.net/problem=101
Code:
import numpy as np
for j in range (1,11):
    M = np.empty([j, j])
    for x in range(1,j+1):
        for y in range(1,j+1):
            M[y,x] = y**(j-x)
    Minv = np.linalg.inv(M)
The ##j^{\mathrm{th}}## estimate ##\mathrm{OP}(j,n)## which fits ##j## data points is a ##(j-1)^{\mathrm{th}}## degree polynomial ##u^{(j)}(n) = a_{j-1} n^{j-1} + \dots + a_{0}## which agrees with ##u_n## on the set ##n \in \{1, \dots, j \}##, so$$\mathbf{a} := \begin{pmatrix} a_{j-1} \\ \vdots \\ a_0 \end{pmatrix} = \begin{pmatrix} 1 & 1 & \cdots & 1 \\ 2^{j-1} & 2^{j-2} & \cdots & 1 \\ \vdots & \vdots & & \vdots \\ j^{j-1} & j^{j-2} & \cdots & 1\end{pmatrix}^{-1} \begin{pmatrix} u_1 \\ \vdots \\ u_j \end{pmatrix} := \mathbf{M}^{-1} \mathbf{u}$$I need to make the matrix ##\mathbf{M}##, why does it not work?
Code:
M[y,x] = y**(j-x)
IndexError: index 1 is out of bounds for axis 0 with size 1
It does not give me the correct answer :frown:
Python:
import numpy as np
sum = 0
def p(k):
    s = 0
    for i in range(0,11):
        s += ((-1)**i)*(k**i)
    return s
    M = np.empty(shape=(j,j))
            M[y-1,x-1] = y**(j-x)
    U = np.empty(shape=(j,1))
    for i in range(1, j+1):
        U[i-1] = p(i)
    A = np.matmul(Minv, U)
    z = 1
    FIT_found = False
    while(FIT_found == False):
        estimate = 0
        for r in range(0,j):
            estimate += A[r]*z**r
        if(estimate != p(z)):
            sum += estimate
            FIT_found = True
        else:
            z = z + 1
print(sum)
I think the idea of doing Project Euler problems is to work on your code until it does :smile:
When posting code here it helps if you add the language so syntax highlighting works:
Python:
import numpy as np
sum = 0
def p(k):
    s = 0
    return s
        U[i-1] = p(i)
    z = 1
    FIT_found = False
        estimate = 0
            sum += estimate
            FIT_found = True
        else:
            z = z + 1
print(sum)
I always get confused by Python's range() function: note that range(1, 11) gives you [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]: this is the first thing I'd check.
And then i'd check that my j, x, and y values are doing what I want in the inner loop (either with an IDE or a simple print statement).
Edit: first of all I'd refactor it so all my loops start at 0, it makes it much easier to keep track.
thanks okay I'm going to finish this tomorrow because I have homework and my stupid code is giving me -670.99996864
  • Haha
:eek: yeah, I don't think that's right.
That’s how I checked the code. I called that seldom used secret programmers function:
Python:
print(‘j = %d, x = %d, y = %d’%(j,x,y))
just before his M assignment.
I'd look for a simpler method of polynomial interpolation if I were you.
