- 13,880
- 16,725
This is covered under speed being coordinate speed, but possibly worth emphasising that "speed of light" here means the one-way speed of light.PeterDonis said:"velocity" and "speed" here must mean coordinate velocity and speed.
Thanks! I'll try to prove this result at least for the case of only ##t## and ##x## dimensions to start with. One more clarification - you mentioned a requirement that the timelike basis vector should satisfy. The only requirement that I can make out is that the speed of free particles is constant, which I guess translates to a requirement on both spacelike and timelike basis vectors?PeterDonis said:Yes, that's a good definition, and note that, in itself, it doesn't assume any particular choice of coordinates; instead, it places requirements on whatever choice of coordinates you are going to make to describe an IRF, since "velocity" and "speed" here must mean coordinate velocity and speed.
So the question you are asking can be rephrased as follows: given these requirements for an IRF and coordinates that describe it, can we show that the timelike coordinate basis vector in any coordinate chart that meets the requirement must be orthogonal to all of the spacelike coordinate basis vectors?
I thought the question is now "why isn't time always orthogonal to space"? Given that it is orthogonal to space in an IRF.PeterDonis said:But that's the wrong place to start from to address the OP's question. The right place to start from is to not assume that time is orthogonal to space, since that's precisely the question at issue.
PeroK said:I thought the question is now "why isn't time always orthogonal to space"?
PeroK said:Given that it is orthogonal to space in an IRF.
Shirish said:you mentioned a requirement that the timelike basis vector should satisfy.
Shirish said:The only requirement that I can make out is that the speed of free particles is constant
Shirish said:which I guess translates to a requirement on both spacelike and timelike basis vectors?
Shirish said:"that the timelike coordinate basis vector in any coordinate chart that meets the requirement must be orthogonal to all of the spacelike coordinate basis vectors?"
Did you mean:
"that the timelike and spacelike coordinate basis vectors in any coordinate chart that meet the requirement must be orthogonal to each other?"
Shirish said:I'll try to prove this result at least for the case of only ##t## and ##x## dimensions to start with.
Okay. So what's our definition of "orthogonal" here?PeterDonis said:The question is whether "it is orthogonal to space in an IRF" must be true, given the coordinate-free definition of an IRF. Saying that "IRF" means "standard Minkowski coordinates" is not an answer to the question, since it assumes precisely what is being questioned.
PeterDonis said:robphy said:Physics (or at least our mathematical formulation of it) defines
spacelike-vectors to be orthogonal to timelike-vectors.
No, it doesn't. This statement is much too strong.
Consider the vectors (in the standard Minkowski coordinate chart) (1,0,0,0)(1,0,0,0) and (0.1,1,0,0)(0.1,1,0,0). The first is timelike and the second is spacelike, but they are not orthogonal.
Even if you restrict the statement to coordinate basis vectors, it is still wrong. It is perfectly possible to have coordinates in which spacelike basis vectors are not orthogonal to timelike basis vectors. Indeed, it is perfectly possible, not only to have coordinates with no timelike basis vector at all, as @Nugatory pointed out, but even to have coordinates with no spacelike basis vector at all. All that is required of basis vectors is that they be a set of four vectors that are linearly independent. That is an extremely weak condition compared to orthogonality.
PeroK said:So what's our definition of "orthogonal" here?
robphy said:timelike vectors are defined first (since I'll regard observers as more primary)
robphy said:given a metric,
timelike vectors are characterized by ##g(\vec t,\vec t)>0## and unit-timelike vectors are characterized by ##g(\hat t,\hat t)=1## ;
robphy said:a spacelike vector then defined as a vector ##\vec v##
that is metric-orthogonal to the timelike vector
robphy said:"spacelike" only has meaning after a metric is introduced.
robphy said:(In my subsequent examples of metrics, the choice of metric determines
which events are simultaneous according the given observer
[i.e. which directions are purely spatial according to the given observer].)
I found that here:PeterDonis said:Two vectors are orthogonal if their inner product is zero. That requires a metric (which we are assuming is the Minkowski metric), in order to have an inner product, but it is independent of any particular coordinate choice.
robphy said:The points I am trying to get across are
PeroK said:Is there a coordinate-free way to define it?
I think I'm starting to get the picture.PeterDonis said:The definition I gave is coordinate-free. You don't need to make any particular choice of coordinates to define a metric and an inner product. If you want it written out in tensor form, the inner product of two vectors ##\vec{u}## and ##\vec{v}## is ##g(\vec{u}, \vec{v}) = g_{ab} u^a v^b##. That will be valid in any coordinate chart.
Shirish said:in the case of Minkowski space, the metric is already predefined as ##\text{diag}(-1,1,1,1)##.
Shirish said:All we have to do is use the conditions for constancy of free particle velocity, and we can try to come up with that set of coordinates which satisfy this requirement.
Shirish said:Does this sound correct?
I can see that for a general metric. But, then, this specific Minkowski metric must be defined by some property. Is is that the (Ricci) curvature is zero everywhere?PeterDonis said:The definition I gave is coordinate-free. You don't need to make any particular choice of coordinates to define a metric and an inner product. If you want it written out in tensor form, the inner product of two vectors ##\vec{u}## and ##\vec{v}## is ##g(\vec{u}, \vec{v}) = g_{ab} u^a v^b##. That will be valid in any coordinate chart.
PeterDonis said:The metric is a coordinate-independent geometric object. Its representation in one particular choice of coordinates is ##\text{diag}(-1,1,1,1)##. But its representation will be different in other coordinates.
PeterDonis said:You need to consider other possible representations in other possible coordinate charts and see if it is possible for any of them to satisfy the requirements for an IRF.
PeroK said:this specific Minkowski metric must be defined by some property. Is is that the (Ricci) curvature is zero everywhere?
Okay, thanks. So that's the defining characteristic here. I don't see how you can progress without that - or, alternatively, specify the metric in some known coordinate system.PeterDonis said:Not just the Ricci tensor; the Riemann tensor is zero everywhere. (The Ricci tensor is zero in any vacuum spacetime, including all of the curved ones like Schwarzschild or Kerr.)
PeroK said:I don't see how you can progress without that
One final thing: what mathematical background would one need to prove the result we want to (regarding the orthogonality requirement of an IRF)? Would linear algebra (up to basic knowledge of covectors / vectors and transformation properties of tensors) suffice? Or would it require more advanced stuff like differential geometry and require me to know fancy concepts like Ricci curvature, etc.? I'll accordingly brush up on the needed mathematical prerequisites.PeterDonis said:Here is an exercise that may help to clarify the above statements of mine.
Consider Rindler coordinates [1]. This is a different coordinate chart on Minkowski spacetime, in which the metric of Minkowski spacetime has a different representation that is not ##\text{diag}(-1,1,1,1)##.
However, this coordinate chart is non-inertial. Try showing this by showing that this chart does not meet either of the two requirements for an IRF: free particles do not have constant coordinate velocity, and light does not always have speed ##c##.
[1] https://en.wikipedia.org/wiki/Rindler_coordinates
PeterDonis said:Without a metric you cannot define timelike or spacelike or null at all for vectors. See below.
Oh no you weren't interrupting, no worriesPeroK said:@Shirish I won't interrupt your thread any more. I was hoping my questions would help you, which I why I asked them. I would have hoped you could learn SR without getting into these deep conceptual waters. From a pedagogical point of view I think this treatment is asking a lot. Rindler coordinates, Riemann tensor, coordiante-free descriptions of spacetime. These are things you need to wrestle with eventually. But, up front I think it's a lot to ask of the student.
Shirish said:what mathematical background would one need to prove the result we want to (regarding the orthogonality requirement of an IRF)?
robphy said:I'll stand by my intuitive characterization
that
"spacelike" only has meaning after a metric is introduced,
robphy said:given an observer's worldline on a position-vs-time graph,
the direction that is "purely spatial" to it
is determined by a metric [say, determined by experiment]
as the tangent line to a conic that describes
the set of point-events equidistant from the origin.
Then
the set of proper metric-preserving transformations will
lead to characterizing a subset of vectors to be "spacelike" from such purely-spatial vectors.
So this is something I managed to do assuming that the transformation from chart ##(t,x)## to ##(t',x')## is linear, constancy of light speed and isotropy/homogeneity of space. We know that in chart ##(t,x)##, by construction, the time and space basis vectors are orthogonal (equipped with ##\text{diag}(-1,1,1,1)## metric). Again because of the way we constructed it, free particles have straight worldlines and light has 45 degree worldlines.PeterDonis said:Since we already have one coordinate chart that satisfies the requirements, we can re-formulate our question as follows: what transformations could we make from this chart to some other chart, that would preserve the two properties required for an IRF (free particle worldlines are straight lines, and light always has speed ##c##)? What constraints can we show must hold for such transformations?
If you find that the required constraints narrow down all of the possible transformations to just the Lorentz transformations in the standard form for the Minkowski chart, you're done
Shirish said:assuming that the transformation from chart ##(t,x)## to ##(t',x')## is linear, constancy of light speed and isotropy/homogeneity of space
Shirish said:the timelike basis vector in the old chart will be mapped to a timelike basis vector in the new one
Shirish said:similarly for spacelike basis vector
Linearity of the transformation follows from the fact that in IRFs free particles have constant speed. The chart ##(t,x)## is rectilinear, so the free particle worldline is straight in it. Assuming that the new chart ##(t',x')## representing another IRF is also rectilinear, that particle's worldline will still be straight due to constant speed. Map from straight to straight worldlines implies linearity. (I'm not sure what we can do if we don't assume that the chart ##(t',x')## is rectilinear.PeterDonis said:The first (linear) shouldn't be an assumption; you should be able to prove that it's required based on the requirements of an IRF.
The second is fine since it's a requirement of an IRF.
The third shouldn't be an assumption either; you should also be able to prove that it's required based on the requirements of an IRF.
Without proofs of the first and third assumptions based on the requirements of an IRF, what you are doing is not proving anything.
Yes, my mistake. I should've said that spacelike (timelike) basis vectors are mapped to spacelike (timelike)PeterDonis said:(If you had left out the word "basis" the second time you used it, your statement would be correct; but it's false with the second "basis" included.)
Same remark as above: basis vectors in the old chart will not be basis vectors in the new chart. Their signature (timelike or spacelike) and norm will be preserved, but not the fact of them being basis vectors.
