Why isn't there a Time operator in QM?
  • Level: Graduate
  • Thread starter Thread starter LarryS
    Operator Time
47 replies · 10K views
meopemuk said:
My point was that formalism of quantum mechanics should be discussed only in the context of a specific experiment. Tell me which experiment you have in mind (what is the observed system and what is the measuring apparatus) and I will be able to answer how you should describe the clock.
Take any experiment (such as the 2-slit) in which particles are detected by hitting a "screen" where they make a "mark". I put these terms in quotes because I don't really know how these things are done in practice.
Now the screen is principally a 3-d object. It extends in 2 spatial dimensions and in time. And just as we treat the screen as theoretically spatially infinite, we can treat it as being fixed in place through all time.
A measurement is made and the result is a mark on the screen. The mark is approximately a 1D object. No spatial extension but it begins at some time and endures indefinitely. That point where it begins is an event (x,y,t) on the 2+1 dimensional screen. From a quantum theory perspective the "measurement" occurs at the appearance of the mark. Or rather, the appearance of the mark at such and such position and such and such time on the 2+1 D screen is the measurement (reduction of the wave function). The 2+1 D screen is a part of the quantum system. Later, we may come in with a ruler and measure (assign numbers) to x and y, just as we can watch the clock to assign a number to t. But those classical measurements are irrelevant to the "quantum measurement".
If, for example, the observed system is an unstable particle, and you are studying its decay probability as a function of time, then the clock is not a part of the quantum-mechanical system. It is a part of the measurement setup. Clock's readings are classical parameters.
In my experiment the clock is part of the measurement setup, true. And equally so is the ruler.
So what about this situation allows us to single out time as a parameter while the position is an observable?
I suspect is that it is non-relativistic approximation, similar to being able to define simultaneity for all observers in classical mechanics (and hence treat time as a parameter).
Hi
As a classic treatise of this problem W. Pauli, in Handbuch der Physik, edited by S. Flugge, Springer, Berlin (1958) Vol.5/1,p.60, showed that a "time operator" T conjugate to a Hamiltonian H could not exist if the spectrum of H is bounded.
Regards.
In order to measure position (to see marks on the screen) you need to have a physical system. You must release an electron in the double-slit setup and find its mark on the screen. Then you can say: electron's coordinates were x and y. So, position is definitely an attribute or property that depends on the state of the electron - the observed physical system. In other words, position is an observable.
You do not need to have a physical system in order to "measure time". You can turn off the electron gun in the double-slit experiment and you can still tell what the time is by looking at the clock. The clock readings do not depend on the state of the observed system. They remain the same even if there is no system to observe (the electron gun is turned off). So, it is not appropriate to call time an observable.
Eugene.
sweet springs said:
Hi
Regards.
You are absolutely right. Introduction of the "time operator" leads to all kinds of paradoxes and inconsistencies.
Eugene.
Eugene, how is this different than saying we can choose an origin, lay out a ruler and read off the positions x and y even if there is no system to observe?
sweet springs said:
Hi
Regards.
The mistake here is the identification of the Hamiltonian with the energy. A time operator would be conjugate to
[tex]E=i\hbar\frac{\partial}{\partial t}[/tex]
, not conjugate to H. The statement of the Schrödinger equation
[tex]H|\psi\rangle=E|\psi\rangle[/tex]
is not the same thing as saying H = E. It is a restriction on the allowed elements of the Hilbert space. Only those state vectors for which
[tex]H|\psi\rangle=E|\psi\rangle[/tex] is true are allowed physical states. If H = E, then [tex]H|\psi\rangle=E|\psi\rangle[/tex] is a tautology and would not carry any information.
See http://www.iop.org/EJ/abstract/0305-4470/36/18/317 for more. (Also here http://arxiv.org/pdf/quant-ph/0211047 )
Sure, you can do that. But these readings are absolutely useless. Their knowledge does not tell you anything interesting about physical processes in nature. This is not physics.
On the other hand, measuring positions of real particles (e.g., electrons) does give you a valuable information about their behavior. Recording times of these measurements is also important for understanding electron's dynamics.
Eugene.
There is no mistake. "Hamiltonian" is just another name for the "operator of energy". The Schroedinger equation
[tex]H|\psi\rangle= i\hbar\frac{\partial}{\partial t}|\psi\rangle[/tex]
is a mathematical expression of the fact that the Hamiltonian H is the generator of time translations.
Eugene.
sweet springs said:
Hi
Regards.
It turns out that Pauli's analysis in not mathematically sound. Actually, the analysis took place in the early 30's when the complex apparatus of Hilbert spaces had not been completed. If there were someone at that time that had the maximal available mathematical knowledge to accomplish Pauli's analysis, then his name could only be Stone, von Neumann who were both MATHEMATICIANS.
Please, see this http://arxiv.org/abs/quant-ph/9908033" published in one of the most prestigious physics journals.
meopemuk said:
I hope you agree that in the QM formalism the observed system is represented by a state vector, while the measuring apparatus (or corresponding observable) is represented by a Hermitian operator.
I don't agree. I think that both are described by a state vector. See e.g. von Neumann theory of quantum measurements.
I fully agree with this.
Hi.
I try to write the essence of mathematics in discussion by W.Pauli. Let us consider a pair of conjugate Hermite operators A and B, AB-BA=i where hbar=1 for brevity. Let |b> be an eigenstate of B with eigenvalue b, B|b> = b|b>. Making a a unitary transformation U(β)=exp(-iβA) where β is any real number, we get the commutation relation BU(β)-U(β)B=β. Applying it to |b>, BU(β)|b>=(b+β)U(β)|b>. So U(β)|b>=|b+β>, eigenstate of B with eigenvalue b+β. Now we know that B should have continuous spectrum spanning from -∞ to +∞.
Let B a Hamiltonian of the system and A a time operator, Hamiltonian should have continuous spectrum spanning from -∞ to +∞.
Regards.
sweet springs said:
Hi.
Regards.
Just this <very essence> is wrong. Your arguments are not mathematically valid. The initial commutation relation takes place in a Hilbert space (actually S), while the rest (underlined), if properly formulated, applies to the functionals' space S' from the Gelfand triple S[tex]\subset[/tex]H[tex]\subset[/tex]S'.
Galapon's argument uses no RHS, but ordinary Hilbert spaces.
Pauli's argument is for me the perfect example of <hand waving>. For me <hand waving> = <mathematically incorrect/unsound> = <plain wrong>.
Thanks for posting. It is encouraging to know I get it.
Hi.
I feel awkward to learn the Gelfand triple S, it seems to be very deep and difficult.
Please just tell me something about the case that A, B are position and momentum. Ordinary QM texts explain U as the translation operator in coordinate or momentum space. Coordinate and momentum have continuous eigenvalues from -∞ to +∞.  The Gelfand triple method should be introduced to this common case also?
Regards.
I don't accept von Neumann's theory of measurement. In my opinion, it is completely unnecessary to invoke dynamical QM formalism to describe the measurement act.
Our argument is philosophical rather than physical, so I don't expect to settle it one way or another. At least we know each other's positions now.
Eugene.
I had the same thought when I looked at Galapon's paper.
Afaict, Pauli's argument still holds if re-expressed in the more rigorous RHS setting.
The basic problem is that an Hermitian time operator satisfying a CCR with the
Hamiltonian is incompatible with the existence of a lowest-energy state.
It can be -- but the essential idea is not so bad. Try the paper quant-ph/0502053.
There's also a readable introduction in sect 1.4 of Ballentine.
Basically, if you're using the Dirac bra-ket formalism and its associated paraphernalia,
you're already working in rigged Hilbert space (aka Gelfand triple) without realizing it.
