Tiny_Explorer
- 16
- 4
Will the existence of tachyons break relativity ? Why light doesn't have mass at most quantum level ? How to mix them up( Quantum mechanics+ Relativity )
Define "break relativity". Tachyons would have very weird properties. They wouldn't be able to slow down to the speed of light or below. If you could observe them, they'd appear to go backwards in time in certain reference frames. Etc.Tiny_Explorer said:Will the existence of tachyons break relativity ?
Ultimately, the fact that light is massless is observed via experimentation.Tiny_Explorer said:Why light doesn't have mass at most quantum level ?
Quantum Field TheoryTiny_Explorer said:How to mix them up( Quantum mechanics+ Relativity )
Matterwave said:Re: the title
Let's improve the quality of this site. We usually ask for effort, what have you searched before? Tell us about your knowledge about the subject, do you know relativity? QFT? what do you really find puzzling, can you be specific?Tiny_Explorer said:Will the existence of tachyons break relativity ? Why light doesn't have mass at most quantum level ? How to mix them up( Quantum mechanics+ Relativity )
What is actually forbidden is for a massive particle to travel at or faster than c, for a massless particle to travel faster or slower than c, and for a tachyon to travel at or slower than c. So tachyons work fine with the actual rule, it is just that the rule is more complicated than a simple “speed limit”.Tiny_Explorer said:According to relativity, you can't break speed of light,but tachyon does , did it break relativity ? We do not have a good experimental setup in world to find tachyon ?
c is defined as the speed of light in vacuum.
That the speed of light is invariant is a postulate of the theory of special relativity. As such, it needs no deeper explanation beyond "we observed it in the laboratory".Herman Trivilino said:Well, you can change the definition to the maximum or invariant speed. Then the question becomes why does light travel at this same speed?
The postulate is that the speed of light is independent of the speed of the source.Matterwave said:That the speed of light is invariant is a postulate of the theory of special relativity.
I'm not sure that's the postulate. The formulations I've seen state it as there being an invariant speed (and light travels at that speed because anything massless does), without saying anything about the speed of the source.Herman Trivilino said:The postulate is that the speed of light is independent of the speed of the source.
How does this follow?Herman Trivilino said:It follows of course that that speed must therefore be invariant.
This is true, but it's not the same as the postulate being what you claim.Herman Trivilino said:Einstein himself was particularly interested in experimental evidence that might show that the speed of light coming from distant astronomical sources might depend on the speed of those sources. Of course, no such evidence has ever been found
In his original paper, Einstein stated the second postulate as, "light is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body." That's also how I recall it being stated in various intro texts.PeterDonis said:I'm not sure that's the postulate. The formulations I've seen state it as there being an invariant speed (and light travels at that speed because anything massless does), without saying anything about the speed of the source.
See the second half of my post.Herman Trivilino said:Of course it would then follow that a pulse of light is not massless.
I have to be pedantic here... sorry, neutrinos were my area of research all those many years ago.Herman Trivilino said:A similar thing happened in recent decades when neutrino oscillations showed that neutrinos are not massless and therefore do not travel at speed ##c##, solving the solar neutrino mystery.
PeterDonis said:How does this follow?
Ah, ok, I had forgotten that last qualifier in Einstein's paper. I don't remember it being stated in Taylor & Wheeler, at least not the version I learned from many years ago, but my memory might be inaccurate; it's been quite some time since I last looked at that text.vela said:In his original paper, Einstein stated the second postulate as, "light is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body." That's also how I recall it being stated in various intro texts.
No, that in itself is not enough. For example, the speed of sound is independent of the speed of the emitter relative to you (the frequency of the sound varies, but the speed does not), but it's not invariant; its speed relative to you is different depending on your speed relative to the medium in which the sound is propagating, and the medium has a definite rest frame.Herman Trivilino said:It's invariant because it doesn't vary with the speed of the observer relative to the source.
This is the kind of derivation I was referring to in post #16.PeroK said:www.physics.umd.edu/~yakovenk/teaching/Lorentz.pdf
Here's a derivation from first principles.
That seems a more modern approach that was possible in 1905.
PeterDonis said:No, that in itself is not enough. For example, the speed of sound is independent of the speed of the emitter relative to you (the frequency of the sound varies, but the speed does not), but it's not invariant; its speed relative to you is different depending on your speed relative to the medium in which the sound is propagating, and the medium has a definite rest frame.
In the original version by Einstein, yes, I think something like that was implicitly being assumed.Herman Trivilino said:Perhaps the assumption of a lack of a medium is also required?
That seems a more modern approach than was possible in 1905.
PeterDonis said:In the original version by Einstein, yes, I think something like that was implicitly being assumed.
I believe that the Einstein's statement of the postulates shouldn't be considered a question for physicists but instead for historians - history of science is an interesting and important discipline, but it's not the same discipline as the science itself. "Independent of the motion of the source" is jarring to the modern ear, so much so that even with his own words under our nose we might assert that that's not the second postulate. But at the end of the 19th century it provided the explicit rejection of Galilean relativity (by rejecting Galilean addition of velocities) that was needed at the time.vela said:In his original paper, Einstein stated the second postulate as, "light is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body."
Indeed, the seminal author of some theory has the first word on the theory, not the last. Subsequent authors can and should improve on it.Nugatory said:I believe that the Einstein's statement of the postulates shouldn't be considered a question for physicists but instead for historians
The sun?javisot said:What source exists for light in a vacuum?
Nugatory said:I believe that the Einstein's statement of the postulates shouldn't be considered a question for physicists but instead for historians - history of science is an interesting and important discipline, but it's not the same discipline as the science itself.
I think a deeper understanding of the physics comes from looking at a more modern derivation based on spacetime symmetries, such as @PeroK referenced. This shows that Einstein's 2nd postulate was really not necessary; you can get to the existence of an invariant speed which must be independent of the speed of the source without having to just assume any of those things a priori. In other words, his formulation, while it worked fine at the time, is not the most parsimonious formulation.Herman Trivilino said:perhaps it can lead to a deeper understanding of the physics.
