Why omit 2xe^{-x}+0.5e^{2x} from a differential equation solution
14 replies · 3K views · last reply
rado5
Handwritten note on a differential equation y'' - y' = 4e^(-x) + 3e^(2x) with y(0)=0, y'(0)=-1, y''(0)=2, followed by a proposed general solution and a question about which terms to omit when applying the initial conditions.
If my solution is right please tell me why I should omit [tex]2xe^{-x}+0.5e^{2x}[/tex]
  • Handwritten note on lined paper: the differential equation y'' - y' = 4e^{-x} + 3e^{2x} with y(0)=0, y'(0)=-1, y''(0)=2; the general solution y(x) = c1e^{-x} + c2 + c3e^{x} + 2xe^{-x} + (1/2)e^{2x}; and a question whether to omit the last two terms and fit c1=3/2, c2=-2, c3=1/2.
You shouldn't omit the particular solution. The initial conditions apply to the complete solution, not just the homogeneous solution.
So the solution of my book is wrong as I expected!
In this case we have
[tex]c_{1}=4 c_{2}=-4.5 c_{3}=0[/tex]
They can't all be 0 otherwise you'd have y(0)=1/2.
Do you know how to solve ODEs with Laplace Transform? it is perfectly suited for constant coefficient ODEs with starting conditions at x=0.
This is a very good advice. I'd take it, in case you know Laplace Transforms.
Really? I wouldn't. I find using Laplace transforms for a problem like this is usually more tedious than solving it using the method of undetermined coefficients.
Depends if you want to solve the inverse LT by hand. :)
But then you have to find the 3 constants that solve the IVP.
and if you solve by Laplace Transform you will find them along the way.
Nevertheless, both ways are good !
and you better know how to solve if by different methods.
Also learn Lagrange's Variation of Parameters, it's a little longer but it's ingenious ! :)
But with the Laplace transform, you'll need to do a partial fractions decomposition, so you end up having to solve a system of linear equations anyway.
I agree it's good to know both ways. It's kind of neat to see it all work out with Laplace transforms, but once you do it a few times, the novelty wears off. ;)
Thank you very much for your kind help. I know Laplace but I have to revise it now.
I actually solved it again and I got the same results:
[tex]c_{1}=4 c_{2}=-4.5 c_{3}=0[/tex] I mean again [tex]c_{3}=0[/tex]
Obviously, you're doing something wrong. Why don't you post your work so we can see where the problem is?
Oh, you did get the right answer. It's just that your equations ran together, so it looked like you got c1=4c2=4.5c3=0 so that all of the coefficients were 0.
If you're going to use LaTeX for something like that, you should put the equations on separate lines. :)
Dear vela, thank you very much for your great generosity!
Dear PhysicsForums thank you very much for your fabulous website!
