Why Parseval's Identity Fails for Higher Exponents in Basel Problem
  • Context: Graduate
  • Thread starter Thread starter Boorglar
    Work
The discussion revolves around the application of Parseval's Identity in the context of the Basel problem and its limitations when extended to higher exponents. Participants explore the validity of using Fourier series to derive sums of series involving inverse powers, particularly questioning why the methods that work for the case of \( n=2 \) do not yield correct results for higher exponents.
  • One participant questions why Parseval's Identity successfully proves the Basel problem for \( n=2 \) but fails for higher exponents, specifically citing their calculations for \( \sum_{n=1}^{∞} \frac{1}{n^4} \).
  • Another participant suggests that there are multiple functions whose Fourier series can yield values for series of inverse even powers, indicating that the original reasoning may be too narrow.
  • Concerns are raised about the correctness of Fourier coefficients calculated by one participant, with another suggesting they may have omitted an important factor and need to consider the zeroth coefficient separately.
  • A participant inquires about a potential analogue of Parseval's identity for the inner product of two functions, linking it to the concept of finding values for sums of reciprocals of cubes.
  • Discussion includes the notion that the inner product of Fourier coefficients could relate to series sums, with references to the "polarization identity" and the preservation of norms in linear operators.
  • One participant hints that applying Parseval's identity to certain functions results in trivial identities, suggesting a misunderstanding in the application of the theorem.
Participants express differing views on the applicability of Parseval's Identity for higher exponents, with some suggesting alternative functions and methods while others maintain that the original approach is flawed. The discussion remains unresolved regarding the correct application and implications of Parseval's Identity in these cases.
Participants note limitations in their understanding of Fourier coefficients and the implications of the zeroth coefficient. There are also references to the need for careful handling of negative coefficients in the context of complex exponential Fourier series.
Boorglar
The solution using the Fourier series of x and Parseval's Identity to prove that
\sum_{n=1}^{∞} \frac{1} {n^2} = \frac{\pi^2} {6}
doesn't seem to work for exponents higher than 2, why?
For example, I found the Fourier coefficients of - \frac{x^2} {4} to be
\frac{(-1)^{n+1}} {n^2}.
So if I use the same reasoning as in the Basel problem:
\sum_{n=1}^{∞} \frac{1} {n^4} = \frac{1} {\pi} \int_{-\pi}^{\pi} \frac{x^4} {16} dx = \frac{\pi^4} {40}
which is not even close to the correct value.How come when Euler does it, it works like magic, but when I try to do the same thing, it fails? Am I doing something wrong? Is Parseval's Identity valid only for the function f(x) = x?
How come when Euler does it, it works, but when I try to do the same thing, it fails? Is Parseval's Identity valid only for the function f(x) = x? Am I doing something wrong?
What "trick" or "reasoning" are you talking about? There are at least 3 more or less simple functions the Fourier
series of which can give the value of the series of inverse squares, and the same can be done with any series of inverse even powers.
DonAntonio
Unlike for the Basal problem, the Fourier coefficient a_0 for the problem you are doing is not zero.
When you account for the a_0^2 term, you should get the correct result.
(By the way, Euler solved the problem using different methods than Parseval's theorem).
Also, I think that your Fourier coefficients are not quite correct. They should be
\frac{1}{2\pi}\int_{-\pi}^\pi f(x)e^{-inx}dx
I don't get your answer of (-1)^{n+1}/n^2. Rather, I get an extra factor of 1/2.
Also, as noted, there are problems with n=0, which you must calculate separately.
Oh I guess that must be my mistake.
And yet it is not obvious to me how the Bernoulli numbers come up. Anyways, I'll work on it more again.
But I have a related question:
is there any sort of analogue of Parseval's identity for the inner product of two functions?
What I mean is, Parseval's identity relates the squared norm (the integral of f(x) squared on some domain) with the sum of the squares of the Fourier coefficients, similar to the way one finds the squared norm of a vector. Could there be a similar relationship between the integral of f(x)*g(x) on the domain with the sum of the products of the Fourier coefficients of f and g? (analogous to the dot product of two vectors).
I'm asking this because zeta(3) could be considered the "dot product" of two sequences, one with Fourier coefficients 1/n and one with 1/n^2 (or with (-1)^n somewhere) and so the same method could have been used.
Parseval's theorem proves that the Fourier transform (discrete or continuous) is unitary. So yes.
Proving that an operator preserves the norm of all vectors is equivalent to proving that the operator preserves all two vector inner products. Furthermore, knowing the quadratic form of any linear operator for all vectors gives you the sesquilinear form of the operator for all pairs of vectors, and thus, completely specifies the operator. Look up the "polarization identity".
But then could this be used to find the value for the sum of the reciprocals of the cubes?
Because you could consider it the inner product of x and x^2 (multiplied by a scalar factor)?
Since the Fourier coefficients of x involve 1/n and the Fourier coefficients of x^2 involve 1/n^2, then the inner product of x and x^2 should involve 1/n^3?
In the interest of full disclosure, I haven't been paying full attention to this thread. I just knew the answer to this last question off hand. I'm not going to swear on anything given any assumptions or workflows that have been presumed already, but I'll say this:
There is an 'inner-product Parseval's identity'. The correct form of it can be seen in the third equation of http://en.wikipedia.org/wiki/Parseval's_theorem. The special case of real functions is shown in the fifth equation.
If you have found functions whose inner-product of Fourier coefficients gives you the series you are looking for, by all means go ahead an do the integral to find the value of the sum. Just don't forget the negative coefficients and don't forget the zeroth coefficient. If your using equation 5 from the link I posted, then the negative coefficients are taken care of. Just remember that those equations are talking about complex exponential Fourier series, not sines and cosines series.
As a hint, if you try to apply the Parseval's identity to x and x^2, and do so correctly, you will find 0=0.
If a_n are the x coefficients and b_n are the x^2 squared coefficients:
a_0=0
a_n for n≠0 are imaginary
b_n are all real.
a_n*b_n is imaginary or zero (either way the real part is zero, and the real part of any sum of such coefficients is zero).
x^3 is an odd function, and any integral symmetric about the origin will be zero.
I suspect you forgot about the factor of i in the coefficients of x.
  • · Replies 16 ·
