Why Is a Particular Solution Necessary in Differential Equations?
  • Thread starter Thread starter LumenPlacidum
A particular solution is necessary in differential equations to address the non-homogeneous part of the equation, which involves a function rather than just zero. The general solution consists of both the complementary solution (yc), which solves the homogeneous equation, and the particular solution (yp), which satisfies the non-homogeneous equation. This structure allows for a complete representation of all possible solutions to the differential equation. The particular solution is essential for meeting specific boundary or initial value conditions. Thus, the complete solution is expressed as y = yc + yp, ensuring it satisfies the entire equation.
LumenPlacidum
If the purpose of the general form of the solution to a differential equation is to represent a formula with parameters for the solutions to that differential equation, why is it that we typically want to add some particular solution to the general one?
Solution = General Solution + Particular Solution.
I suppose I understand why you'd want it there, but the part that I don't remember from my Diff. Eq. stuff from long ago is why the particular solution is not included in the general solution.
The particular solution is for the corresponding non-homogeneous equation. In other words, on the right hand side of the differential equation, zero is replaced with some function.
A particular solution is a solution that satisfies boundary or initial value conditions. It shows up in inhomogeneous differential equations, as far as I recall.
So, is this appropriate?
The general solution for a non-homogeneous system of differential equations is analogous to the +C of integration. Because of the superposition principle, any function of the form of the general solution COULD be a part of the solution for the ODE since it would have become exactly zero upon substitution for y.
No, this isn't quite right. It is General Solution = Complementary solution + Particular Solution = yc + yp. The complementary solution is the solution to the associated homogeneous problem.
The homogeneous problem is f(t, y, y', ... ,y(n)) = 0; for example, y'' + 4y' + 4y = 0.
The nonhomogeneous problem is f(t, y, y', ... ,y(n)) = g(t); for example, y'' + 4y' + 4y = t.
The solution to the homogeneous problem is a linear combination of e-2t and te-2t. As it turns out for my example, the particular solution is yp = -5/4 + t/4.
We know that yc is a solution to the homogeneous problem, which means for my example, yc'' + 4yc' + 4yc = 0. We also know that yp is a particular solution of the nonhomogeneous problem, so yp'' + 4yp' + 4yp = t.
Then for a general solution y = yc + yp, we will have y'' + 4y' + 4y = t, regardless of which linear combination of e-2t and te-2t we choose.
  • · Replies 52 ·
