Why would a petrol engine stall at an altitude?
  • Thread starter Thread starter Kelly Andrew
    Altitude Engine
The discussion centers on the reasons a petrol engine may stall at altitude, particularly in the context of a small homemade aircraft. Key factors include improper fuel tank switching, lack of oxygen, fuel pump failure, and mechanical issues. The engine requires a consistent supply of fuel, air, oil, and ignition; any disruption can lead to stalling. Additionally, pilot error, such as selecting an empty fuel tank, can also result in engine failure.
  • Understanding of basic aircraft engine mechanics
  • Knowledge of fuel systems in small aircraft
  • Familiarity with the impact of altitude on engine performance
  • Awareness of common pilot errors that affect engine operation
  • Research the operation of dual fuel tank systems in small aircraft
  • Learn about the effects of altitude on engine performance and oxygen levels
  • Explore troubleshooting techniques for common engine failures
  • Study the principles of carburetor icing and prevention methods
Aerospace engineers, pilots of small aircraft, aviation mechanics, and anyone interested in understanding the operational challenges of petrol engines at altitude.
Kelly Andrew
The engine was used to propel a small home made air craft. It worked very well while it taxied away and went airborne, then at a certain altitude it stopped abruptly then came crashing down. Why? And what simple engine design can sustain the air craft?
It seems you're asking about why an engine would stall at a certain height, right?
My friend, who was a pilot of small aircraft told me that there are two gas tanks and a valve that you use to switch between tanks. Sometimes if the pilot isn't careful he/she may switch to the secondary tank but not switch it all the way. Consequently the engine stalls due to lack of gasoline.
Other reasons why an engine might stall is due to lack of oxygen either because something has lodged in the air intake or its flying too high or due to a fuel pump failure.
Is this manned or a model/drone? Is the fuel pumped or gravity fed?
There are many reasons that an airplane engine can stop running.
An engine needs fuel, air, oil, and ignition to run. Take away anyone of those, and the engine stops.
An engine consists of many mechanical parts. If the wrong part breaks, the engine stops.
An engine has a cooling system. If that system fails, the engine can stop. Think bird nest in an air cooled engine.
The engine is operated by the pilot. If the pilot does certain things wrong, the engine stops. Taking off with fuel selector on an empty fuel tank is a popular way for an engine to stop shortly after lifting off. A friend did that.
Wrong fuel. Jet fuel in a gasoline engine. Water in the fuel. I experienced a fuel line freeze up one night over the Black Hills of South Dakota. Fortunately, the fuel line from the other fuel tank was not frozen.
Icing in carbureted engines.
  • · Replies 26 ·
9K
