Will BP's Top Kill Procedure Stop the Gulf Oil Spill?
  • Thread starter Thread starter Glennage
238 replies · 31K views
jackmell said:
Let me play the devil's advocate:
When they make the second cut near the top of the BOP stack, the oil flow dramatically increases 10-fold...
BP has calculated that the flow rate will not be siginficantly affected. Apparently the existing kink in the pipe is not enough to significantly reduce the flow. From there it is basically just an open pipe.
Ivan Seeking said:
It is the oil equivalent of an artesian well. The effective differential pressure between the well head, and the water at depth, is supposed to be about 2500 psi.
I'm not sure about the source of pressure in the oil field itself. I think it results from the natural gas that is present.
Years ago I worked for a company that manufactured liners, pistons, rods and seals, for mud pumps, IIRC most pumps would maintain pressures around 5,000 psi, but this covered the difference of well pressure and circulating mud pressure.
The plume of oil and gas from the first views of the remote cam, looked as if the well pressure might only exceed water pressure by a small amount. (just my thoughts)
That's very good Ivan. And thanks for that. Personally I've maintained a lot of confidence in BP throughout this problem. Seriously. And I hope all goes well. However, those calculations wouldn't work for me if I was top dog. I'd say start fabricating the funnel anyway and have it delivered to the site ready to be installed if problems are encountered.
No offense. :)
It did seem to be billowing, not jetting out.
Geigerclick said:
This is purely supposition on my part, but when large things sink through nearly a mile of water, they do not sink directly downward. I would expect the remains if the rig to be some distance in the direction of the prevailing currents when it sank, so, north of the well.
A map showing Deepwater Horizon rig location relative to BOP site.
http://www.upstreamonline.com/multimedia/archive/00034/Deepwater_Horizon_lo_34332a.jpg
Source - http://www.upstreamonline.com/live/article213131.ece
The scale is difficult to read, but I believe the rings are 200 ft, so DWH is about 1100 ft from the BOP.
Keep in mind that that we have a 26-inch diameter, open pipe, spewing oil. So, yes, one would expect that the oil coming out of the other holes is near the pressure at depth. However, if one tried to plug the hole, as they did while driving down the mud, the full 5000 psi would come into play.
I am not sure why barack obama has said that he was enraged that the top kill effort failed. I can understand being enraged at the original accident, but why woul he be enraged by failure of this specific procedure? If he knew that it was bound to fail beforehand, shouldn't he have said something?
When they make the second cut near the top of the BOP stack, the oil flow dramatically increases 10-fold and this causes great difficulty steering the LMRP cap onto the flange of the BOP. Additionally, the increase oil flow greatly disrupts visuals in the work area.
Then what?
Here's my plan:
Rig an inverted funnel, say 10' in diameter and maybe 10' deep onto the LMRP (such that it won't interfere with the BOP) cap to guide it squarely onto the stack. Didn't see any type of device in the pictures. It should not be a solid funnel but rather a coarse screen funnel that allows a great amount of fluid to pass through it while sufficiently maintaining it's structure. If necessary, use sophisticated video equipment that can see through the oil. Also, keep the LMRP cap open while it's being installed to allow the oil to pass through.
Yeah, I realize they know way better than me. Just havin' a lil' fun. :)
I don't know what a "LMRP" is, but control of the oil to the surface should be the first thing done while the main repair or closing of the well is being worked on.
As I commented before, a fabric funnel can direct the oil and gas to the surface where it is retained inside a large ring. This large ring might need to be as large as a 1/4 mile (or more) in diameter, something able to retain a floating mass of oil as much as 2 meters thick. Finding and delivering flat deck barges for the floating ring might take a little time.
There is a solution to all problems, this one needs to be quick.
What are your talking about? BP claimed 60-70% confidence that top kill would work.
I think that like everyone, he is angry about the entire situation.
http://uk.news.yahoo.com/5/20100530/twl-obama-enraged-by-bp-oil-plug-failure-3fd0ae9.html
Has anyone noticed that no one seems to be complaining about how they want the government out of their life? What happened to all of our fiscal libertarians? Why aren't the tea drinkers protesting?
Thanks,:smile:
You said that he knew it would fail. Was that intentional misinformation?
It's difficult to find good data on the Macondo well, but I did find this.
Mission
Suttles said on Friday that the first of two relief wells at Macondo was “slightly ahead of schedule”
The Transocean semi-submersible rig Development Driller III has resumed drilling the first relief well after stopping to test and drop the BOP on 9 May.
The Transocean semi-submersible rig drilled out of a 22-inch casing Friday was continuing down hole Monday at 10,100 feet below the drilling floor.
Another Transocean semi-sub, Development Driller II, is drilling the second relief well.
Development Driller II set the top 36-inch casing on its relief well and has stopped drilling at 6750 feet while it performs routine tests on its BOP.
Both wells are planned for casing strings of 36, 28, 22, 18, 16, 13-5/8, 11-7/8 and 9-5/8 inches, the same string as the original Macondo well.
Ref: http://www.upstreamonline.com/live/article215908.ece
I'm not sure about the riser diameter, but I believe it is on the order of 20-21 inches OD.
I agree, but think about the difference between the plumes of free flow oil, gas and then the plume of mud under pressure.
No, I didn't, reread my post. My point was, why was he "enraged" by the failure of the top kill procedure? It makes sense to be disappointed, but "enraged" implies that someone did something wrong. In other words, if he had said to BP, "guys, this has no chance of working" but they did it anyway and it failed, then being enraged would make sense. Being enraged at a sincere attempt to fix the problem that failed doesn't make sense.
Uhhh I don't really think any of this follows logically. I'm pretty angry that this topkill procedure didn't work and that's all that enraged means. The word doesn't imply anything about someone doing something wrong. It also doesn't matter how likely it was to fail or succeed. You can still be enraged or angry when something with a 90% success rate fails.
LMRP=Lower Marine Riser Package (LMRP) Cap
Installing a Lower Marine Riser Package (LMRP) Cap is a containment option for collecting the flow of oil from the MC252 well. The LMRP is the top half of the blow out preventer (BOP) stack.
The installation procedure first involves removing the damaged riser from the top of the BOP.
A remote operated hydraulic shear will be used to make two initial cuts and then that section will be removed by crane. A diamond wire saw will then be placed to cut the pipe close to the LMRP and the final damaged piece of riser will be removed.
The LMRP Cap is designed to seal on top of the riser stub. The seal will decrease the potential of inflow of seawater as well as improve the efficiency of oil recovery. Lines carrying methanol also are connected to the device to help stop hydrate formation.
The device will be connected to a riser extending from the Discoverer Enterprise drillship.
The LMRP Cap is on site, and it is anticipated that this option would be available for deployment by the end of May.
from link provide earlier.
When Deepwater Horizon sank, it pulled and distorted the riser that was connected to the rig and BOP. Apparently the oil is leaking from the riser in 2 (perhaps 3?) locations. The goal is to cut the riser the top of the BOP and connect the LMRP to 'cap' the BOP and stop the leak. In cutting the riser, the oil flow may increase, but BP hopes it is not significantly more than is coming out now (I heard a comment of a 10% increase). Hopefully then, they LMRP is intalled quickly after the riser is cut.
The BOP sits atop the well casing. The idea of pumping drill mud into the BOP was to displace the ligher oil with heavier mud to slow the flow.
I presume the siphon (5-6 inch dia) was passed through the break in the riser, but they're not drawing fast enough to capture the entire oil/gas flow.
Jimmy Snyder said:
Heat it to 21 degrees C?
16 degrees C above a surrounding ocean. Oceans tend to object to large heat gradients; they're like that. Anyway, looks like that's what they are doing next: the dome, top cover trick again this time with heat and methanol as antifreeze.
Ivan Seeking said:
This is not the place for a technical discussion.
Well then... Since the Top Kill has failed, should we mention a place for the discussion to continue, and close this thread?
Physics Forums > Engineering > Engineering Systems & Design
Astronuc said:
I have to wonder that if BP could insert a pipe into the hole, why not insert a heavy plug - made of something dense like tungsten or depleted U, such that the pressure drop would allow pouring of mud or concrete above the plug, which would seal the hole. Admittedly, I don't know the details of the geometry of the hole.
The plug may not necessarily require a dense material, but just be heavy enough to settle into the hole. The denser the material, the smaller the plug and perhaps more manageable.
After cutting the riser flush, the opening would be ~300 in^2. At 5000 PSI (?) well pressure, the plug would have to weigh ~750 tons, or have that much force applied to it somehow. After the plug is in place, maybe the ocean's 2500 PSI could help opposing the oil pressure, but I don't think before. Probably not possible to push down from a mile up; perhaps they could pull it down, with tension from sea floor anchors. Anyway, required plug weight suggests it is much easier to allow the oil/gas to continue in a controlled, captured flow it possible.
How did they pump mud, and do a junk shot, into a kinked over pipe?
jreelawg said:
How did they pump mud, and do a junk shot, into a kinked ver pipe?
The mud was pumped directly into valves on the blow out preventer, i.e. 'upstream' of the bent riser. Google for a pic of the top kill mechanism.
Good point, Top Kill is done, so, this thread would seem to be as well.
Actually, I think I've changed my mind. I'm now going to ask that this thread be left open, such that people can vent their frustrations about the situation. GD is good for that. :smile:
Leave it open. The phrase "Top Kill" will probably be relevant again when the prosecutions begin. :wink:
:smile:
That, or as a play on words when the firing squads take aim...
