Will These Motors Be Powerful Enough?
  • Thread starter Thread starter rocketbuilder
    Motors
The discussion revolves around the suitability of six 12 Volt DC motors, each with 120 RPM and 60 Newtons * cm of torque, for a rover weighing 15-18 lbs. The user seeks to ensure the motors can handle a maximum incline of 35 degrees while maintaining a slow walking pace. Calculations indicate a required torque of approximately 2.25 lbs force per foot to climb the specified slope, factoring in a 50% efficiency loss. The user also inquires about the impact of wheel diameter on torque calculations. Overall, the conversation focuses on the motor's capability to provide adequate power and torque for the rover's intended use.
rocketbuilder
Hi everyone,
I plan on getting a deeper understanding of this soon, but for the time being I'm just looking for a quick answer so I can order the parts needed.
I'm building a rover that in total (including all parts) will weigh about 15-18 lbs. It has six equally spaced legs, each connected to a 4.5 inch diameter by 3 inch wide wheel with rubber treads. Each wheel has a small hub connected to it where the 4mm shaft of the motor will be held. My question is, will 6 small 12 Volt DC 120 RPM motors with 60 Newtons * cm of torque be enough to move the rover around? I'm not really concerned with speed as long it can move at about a slow walking pace. My bigger concerns are will it move and will there be enough torque for it to make it up small hills of modest inclination (given that it has some traction).
Thanks so much
Welcome to PF!
What slope are you looking to try to climb?
Thank you!
I guess there really isn't one set slope that I want the rover to climb. I want it to be able to move around in different environments, but let's just say the maximum slope it would try to climb would be about 35 degrees.
thanks again
Ok, can you use some geometry and the equation for potential energy to calculate the power required to do that? (And throw in an efficiency factor of 50%.) Then you can use that power and the RPM to find the torque required of the motors. Give it a shot...
Ok, so I did some calculating and ended up with about 2.25 (rounding up a bit) lbs force per foot for the torque needed to climb a slope of 35 degrees and a height of about 5.73 ft given it's hypotenuse is 10 ft. I also took into account the 50 percent EF when calculating the power. Do these numbers sound somewhat correct? Also do I have to take into account the diameter of the wheels? My formula for calculating torque was T= hp(converted from power) X 5252 / rpm
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
