Wing Aspect Ratio (Newbie to Aerodynamics)
The discussion focuses on calculating the aerodynamic mean chord of a delta wing with a mass of 9072 kg, an aspect ratio (AR) of 1, and an area of 37 m². The aerodynamic mean chord is defined by the integral equation \(\frac{\int_0^{b/2} c^2 dy}{\int_0^{b/2} c\ dy}\), which results in a value of 5.73 m for this specific wing configuration. Participants express confusion regarding the relationship between wingspan and mean chord, particularly in the context of delta wing design.
  • Understanding of aerodynamic principles, specifically delta wing design
  • Familiarity with integral calculus as applied to aerodynamics
  • Knowledge of the concept of aspect ratio in aircraft design
  • Basic grasp of wing geometry and chord definitions
  • Research the implications of aspect ratio on delta wing performance
  • Study the derivation of the aerodynamic mean chord for various wing shapes
  • Explore integral calculus applications in aerodynamics
  • Learn about the characteristics and design considerations of tailless aircraft
Aerodynamics students, aerospace engineers, and anyone involved in aircraft design or performance analysis will benefit from this discussion.
t.kennedy
A tailless aircraft of 9072kg mass has a delta wing with aspect ratio 1 and area 37m2. Show that the aerodynamic mean chord of a delta wing,
is two-thirds of its root chord and that for this wing it is 5.73m.
AR= \frac{b}{\bar{c}}
Problem 1.
AR= \frac{b}{\bar{c}}=1
b= \bar{c}
I don't get it. If the wingspan equals to the mean chord then it won't be delta wing anymore, wouldn't it?
As you can see the root chord is smaller than the tip chord hence \bar{c} must be smaller than b/2. Where do I get myself wrong?
Problem 2
How do I find the equation for c to solve this integral? Is there any of other way? I know the bottom integral is the area of one wing but I don't know the other one.
I can't help with the rest of the problem but if I don't see a problem with the wingspan being equal to the mean chord. The plan form won't be an equilateral triangle but it would still be a triangle and classed as a delta.
16K
11K
