With which speech goes the Mass through the Equilibrium?
The discussion revolves around calculating the speed of a mass at equilibrium in a thermodynamic context. The relevant equations include kinetic energy (Ekin = 1/2*m*v²), potential energy (Epot = m*g*h), and elastic energy (Es = 1/2*D*s²). The total energy at the highest point is approximately 6.573 Nm, derived from a mass of 1 kg at a height of 0.67 m. The problem was ultimately resolved by applying the given data directly into the equations, confirming the solution's validity.
  • Understanding of kinetic energy and potential energy equations
  • Familiarity with thermodynamic equilibrium concepts
  • Basic knowledge of energy conservation principles
  • Ability to manipulate algebraic equations
  • Study the principles of energy conservation in mechanical systems
  • Learn about thermodynamic equilibrium and its implications in physics
  • Explore the derivation and application of kinetic and potential energy formulas
  • Investigate real-world examples of energy transformations in dynamic systems
Students in physics, educators teaching energy concepts, and anyone interested in understanding the dynamics of mass and energy in thermodynamic systems.
wiegetz
With which speed goes the Mass through the Equilibrium?
Es = 1/2*D*s2
Ekin = 1/2*m*v2
Epot = m*g*h
Energy in the zero point = below/ under
highest Point: Epot = 1kg * 9,81N/kg*0.67m
≈ 6.573Nm
Equilibrium : Ekin, Epot, Es
Lowest Point: Es= 0 Ekin = 0, Epot = 0
I have no Idea what I have to do. I found out that the total Energy needs to be approx. 6,573Nm of the system.
Your problem statement makes no sense.
What speech? What equilibrium?
Sorry, I ment speed, not speech. The question is asked on a different language, so I tried to translate it. According to google, the correct meaning should be "
Thermodynamic equilibrium
OK, things are a little clearer now. But what about the particulars of this problem? What does 0.67 m have to do with anything?
I solved this problem. I needed to insert the given data simply into the formula, I thought that this attempt would be too simple. Can be marked as solved!
  • · Replies 27 ·
  • · Replies 29 ·
