Wolframalpha it says the limit does not exist
  • Thread starter annoymage
    Limit
4 replies · 2K views · last reply
annoymage
use definition for the limit of a function to show that
[tex]\lim_{(x,y)\rightarrow (0,0)} xcos\frac{1}{y}[/tex]
n/a
fisrt, i assumed it the limit is 0(i don't know if it is true), but i showed it, but something bugging me, i put in wolframalpha it says the limit does not exist, http://www.wolframalpha.com/input/?i=lim+xcos(1/y),(x,y)->(0,0)
so who is wrong here?
at a quicklook
|cos(1/y)|<=1 for all y's,
so you can choose x small enough to bring you close enough to zero. The function will oscillate with increasing frequency, but with decreasing magnitude as you approach the origin
lanedance said:
at a quicklook
so, it really approaches to 0, but how come wolfram-alpha say it does not exist. did i wrote anything wrong?
A limit of a function of several variables fails to exist if there are different limits from "different direction" i.e. from the "x" and "y" directions:
Thus, you need to check if the limit as x -> 0 (treat y as a constant) of the function is the same as the limit as y -> 0 (treat x as a constant).
Let's check limit from x direction:
lim[x->0] x*cos(1/y) = 0*cos(const.) = 0
But there is a problem with the limit of cos(1/y) when y->0.
http://www.wolframalpha.com/input/?i=lim+cos(1/y),+y->0
do you know why there is a problem with that y->0 limit? :)
Good Luck.
yeah its an interesting one...
cos(1/y) is cleary undefined anywhere on the line y=0, so no limit on that line will exist for any function of cos(1/y)
however, it does have the property that as you get close to x=0, |x||cos(1/y)|<=|x|which tends to zero
also just to add, checking 2 startight line directions is suffcient to show a limit dne, but not to prove it exists
