Work done by a constant force problem
6 replies · 5K views · last reply
mooney82
A 1.8kg block is moved at constant speed over a surface for which uk = 0.25. The displacement is 2 m. It is pushed with a force at 45 degrees below the horizontal.
Find the work done by: (a) the force F; (b) friction; (c) gravity
W=Fs cos (theta)
s=displacement
First I found the force F to be 6.24 N.
Then using W=Fs cos (theta) I put in:
W=6.24 N * 2 m * cos 135
W= -8.82
The answer in the back of the book says 11.8, I'm wondering where I'm making my mistake.
How did you solve for the force?
Why did you use an angle of 135? (That's why your answer is negative.) But first figure out the force properly.
Well, I summed the x component forces:
Fcos45 - friction = ma
acceleration = 0
friction = uk(N)
N equals mg
so
Fcos45 - uk(mg)=0
F = uk(mg)/cos45
F = 0.25*1.8*9.81/cos45
mooney82 said:
N equals mg
Here's the problem. In this case, N ≠ mg. The fact that the applied force has a vertical component changes the normal force.
To find the normal force, analyze the vertical components of the forces acting on the block.
Would you then solve by substitution? I'm having a hard time because F seems to cancel out.
Yes. You'll have two equations: one for vertical forces; one for horizontal. You can eliminate N by substituting one into the other.
Show what you're doing.
I got it to work out. You tha man Al!
