Work done by pumping water into a tank
1 reply · 5K views · last reply
jdroidxw
Problem with picture attached
I need help on 24. **24 is a continuation of 23 so use the same dimension except for the distance...
Or you can go here http://college.cengage.com/mathemat...alc8e_solution_main.html?CH=00&SECT=a&TYPE=se
Chapter 7, Lesson 5
Volume=∏r^2*Δy
Water= 9800 N/m^3
∫(Volume)(water)(distance)=Work done ??
Volume= 4∏Δy
Weight=9800*4∏Δy
Distance is where I'm not too sure about. Would I use (10-y)??
If so then I got...
∫9800*4∏Δy*(10-y), from 0 to 4 = 1,254,400∏ N-m
My answer looks really huge... Did I mess up anywhere?
Welcome to PF, jdroidxw! :smile:
You have the infinitesimal weight correct with 9800*4∏dy.
How far does the water that ends at the bottom have to be pumped up?
And how far does the water that ends at the highest level have to be pumped up?
