Work done by stretching a STring
nickclarson
I have been looking all over for an equation to find the work done on a steel string that is stretched L meters.
"Find the work needed to stretch the string."
I know it has variable forces so I was thinking I could use elastic potential
U=\frac{kx^{2}}_{2}
but now I have the problem finding out what K is.
ANY help is appreciated thanks.
Nick
Is this a homework problem? That can't be the full question. You've got the right idea if the steel wire can be considered as a spring. You'll need a modulus of elasticity and the geometry of the wire to actually do this.
yea I have the area of the wire and the modulus... I just need help figuring out which equation to use.
Thanks,
Nick
Didn't they give you a formula for that as well? The elastic modulus Y, has units of N/m^2, yes? k should have units of N/m. So I would guess on purely dimensional grounds that if L is length and A is cross sectional area that k=Y*A/L. Can you confirm that by doing some research? Units are your friend. Exploit them.
