Work done on the block by force
5 replies · 4K views
Zmuffinz
A block is pushed across a rough horizontal surface from point A to point B by a force (magnitude P = 5.4 N) as shown in the figure. The magnitude of the force of friction acting on the block between A and B is 1.2 N and points A and B are 0.5 m apart. If the kinetic energies of the block at A and B are 4.0 J and 5.6 J, respectively, how much work is done on the block by the force P
between A and B?
W= PCos (theta)D
I have no idea what to do for this!
I suppose Work done on the block = change in kinetic energy + work against friction
Welcome to PF!
Hi Zmuffinz! Welcome to PF! :smile:
(have a theta: θ :wink:)
Zmuffinz said:
W= PCos (theta)D
Well, what is θ in this case? :smile:
well you see that's why I am stuck, i wasnt given an angle, or mass of the block or anything so I've got no clue as to what to do:(
and how do i calculate work against friction?
You didn't post the diagram, but I presume that the force was applied horizontally. That will tell you all you need about angles.
