How Much Work Is Needed to Alter a Crate's Velocity?
The discussion centers on calculating the work required to alter the velocity of a 34.0 kg crate from 3.70 m/s at 37.0 degrees west of north to 6.08 m/s at 63.0 degrees south of east. The work-energy theorem, represented by the equation W=1/2mvf^2-1/2mvi^2, was applied to determine the work done in both x and y components. Initial calculations yielded incorrect results due to misapplication of vector addition; the correct approach involves treating work as a scalar quantity and summing the work done in each direction algebraically. The final calculated work is 354.32J.
  • Understanding of the work-energy theorem
  • Knowledge of vector decomposition in physics
  • Familiarity with scalar vs. vector quantities
  • Basic proficiency in trigonometry for angle calculations
  • Review the work-energy theorem and its applications in physics
  • Study vector decomposition and how to handle components in physics problems
  • Learn about scalar and vector quantities and their implications in calculations
  • Practice problems involving work calculations with varying angles and directions
Students studying physics, particularly those focusing on mechanics and the work-energy principle, as well as educators looking for examples of common misconceptions in vector calculations.
jtc143
A 34.0 kg crate is initially moving with a velocity that has magnitude 3.70 m/s in a direction 37.0 degrees west of north. How much work must be done on the crate to change its velocity to 6.08 m/s in a direction 63.0 degrees south of east?
W=1/2mvf^2-1/2mvi^2
I attempted this by breaking the velocities into their components and got -2.23m/s in the initial x, 2.95m/s in the initial y, 2.76m/s in the final x, and -5.42m/s in the final y. Then I did the work-energy theorem for both x and y components and got work in x direction to be 44.96J and work in the y direction to be 351.46J. Then I did the Pythagorean theorem to get work to be 354.32J But this is wrong, can anyone help?
Never mind I figured it out. The angles mean nothing and you just do the work energy theorem normally. However, I'm not sure WHY this is so; can anyone explain why the angles do not effect the question?
Work, like energy, is a scalar quantity, and as such, it has no direction, only magnitude, which may be a positive or negative value. In your first attempt when you broke up the velocity into its vector components, if you did the math correctly, you get the same answer as the correct answer, provided that when you get the two values of work you then add them up algebraically, not vectorially, that is, you don't use Pythagorus (there is no direction associated with work, so just add them up).
  • · Replies 56 ·
