Work needed to move opposite charges farther apart
  • Thread starter Thread starter mikil100
    Charges Work
The discussion revolves around calculating the work required to separate two equal charges of opposite sign from an initial distance of 6.7m to a final distance of 7.9m. The problem involves concepts from electrostatics, particularly the relationship between work, potential energy, and the forces acting between charged particles.
  • Participants discuss using the formula for work in terms of potential energy differences and the electrostatic force between the charges. There is consideration of how to handle the signs of the charges and the implications for the calculations. Some participants suggest integrating the force over the distance to account for the changing force as the charges are separated.
There is an ongoing exploration of different methods to calculate the work done, with some participants questioning the validity of their approaches and calculations. Guidance has been offered regarding the need to consider potential energy at both initial and final distances, and there is acknowledgment of the complexity introduced by the changing force with distance.
Participants note the constraints of working within an algebra-based class, which may limit the use of calculus for integration. There are also mentions of rounding errors in calculations that affect the accuracy of results.
mikil100
Suppose you want to move two charges apart, both are equal charges of opposite sign at 1.4x10^9C, and their starting position is 6.7m apart, how much work would it take to further separate the charges to a final distance of 7.9m, that is, move them 1.2m
W=Kq1q2/r[/B]
[/B]
I have gotten an answer at 1.5x20^28 J, this was by taking the distance 1.2m and using it as the distance traveled-plugging it into the equation-- I also made an assumption that both charges, while opposite sign are treated with absolute value, otherwise I get negative work which doesn't seem to make sense as it is working to separate the charges from on another, therefore increasing potential energy.
Hi mikil100, Welcome to Physics Forums.
Your Relevant equation is not quite right. As it stands it doesn't express work, but potential energy in the configuration of two charges q1 and q2 that are a distance r apart. So your answer that came from considering r to be the change in separation is not right.
So a valid approach for you would be to consider the potential energy at the initial distance and the potential energy at the final distance. The difference between them would be the work done to move from one position to the other.
Alternatively you could consider the electrostatic force between the charges and do the Force x distance integration over the path from the initial separation to the final separation.
Your observation on dealing with the signs of the charges is a good one. When you're contending with charge signs affecting the force directions and choices of coordinate system axis directions, it can get tricky to juggle all the parameters of the problem. It's always a good idea to draw a sketch and determine the directions of the forces and their relationships to any movement made. Then go ahead and use absolute values for the charges and use signs that you determined from your sketch on the terms to specify the directions.
So I could simply calculate the distance traveled, being 1.2m by multiplying it by the force interacting between the two charges ( using the formula F=k(q1q2)/r^2?
Using W=F*d I get 4.68x10^26
If I use the other method, being position initial-position final (which would have lower PE) , it would be (k(1.4x10^9)^2/6.7) - (k(1.4x10^9)^2/7.9) equalling 4.3x10^26
Does this seem equatable? Thank you for your help!
Nope. Because the force changes with distance. That's why I mentioned doing the integration over the path.
You may want to go back to your calculator there. I'm not seeing that value as a result with those figures punched in. What value are you using for k?
Ah, okay... that makes sense, unfortunately this is an algebra based class I am taking and my own personal ability at integrating is limited.
I am using Coulombs constant for k, at 9x10^9.
I rechecked my math and I have rounding error, carrying the equation through with my calculator I get a value of 3.99x10^26. Does this seem more accurate?
Yup! Much better. Be sure to specify the units when you submit your answer!
  • · Replies 21 ·
  • · Replies 23 ·
