Work required to increase Earth/Moon separation
5 replies · 2K views
The Moon and Earth have masses of 7.4 × 1022 kg and 6.0 × 1024 kg, respectively, and the distance between their centers is 3.8 × 108 m. The amount of work required to pull them further apart so that their separation increases by a factor of 1.6 is most nearly
Etot = -GMm/(2r)
W=ΔE
ΔE=(-GMm/2)(1/(1.6*3.8 x 108) - (1/3.8 x 108)) = 1.44 x 1028 J
Answer key says 2.9 x 1028 J
That's twice my answer. Is it possible that the person who made the answer key forgot to factor out the /2. Or should I be considering only ΔU? I did a similar problem from this chapter using ΔEtot and got the right answer. What am I missing?
Thanks!
Is the moon still in a stable circular orbit? I think if the motion of the moon is not considered than we have to take only change in potential energy.
What energies does your Etot include?
Why don't you do a check of the result by performing the work integration (integral of F.dr) for the increase in separation?
tony873004 said:
Etot = -GMm/(2r)
Why is the 2 here? The potential energy of the system is just -GMm/r
gneill said:
What energies does your Etot include?...
That formula is for total energy, not PE
U=-GMm/r
KE=0.5mv2, v=sqrt(GM/r)
KE=0.5 GMm/r
KE=GMm/(2r)
U=-2GM/(2r) --add the 2's so U and KE have a common denominator
KE+U=(GMm/(2r)) - (2GMm/(2r))
KE+U=-GMm/(2r) = Etot
I think mukundpa solved it. The problem did not state that the Moon achieved a circular orbit at the new distance. So with its velocity constant, all that changed is the PE. Doing the problem that way, I get the answer the key is looking for.
Thanks everyone!
another way to interpret it, is that they wanted the work done, given that the kinetic energy of the moon and Earth do not change.
