Writing: Input Wanted How can a wormhole be relocated and what would happen to objects near it?
Wormholes, as discussed, are fixed positions in spacetime and are not affected by gravity or other forces, making their positioning complex. The possibility of relocating a wormhole is acknowledged, but the mechanics and energy requirements for such movement remain unclear. When a large object encounters a wormhole, it is suggested that only particles small enough to fit through will pass, creating a round tunnel effect in the object. The conversation also touches on using cosmic references for positioning wormholes and the potential for setting fixed distances between their ends as space expands. Ultimately, the narrative flexibility allows writers to define the rules of wormholes to suit their stories, while maintaining internal consistency.
Michael27
Hi
I am writing a short story about wormholes being used as a plot device.
I know wormholes have no stable solutions unless you put some form of exotic matter or other means of stabilizing the geometry. I assume that I have a wormhole of any size which is stable when other matter comes near it.
My questions are simple (but maybe not the answers):
  • Does gravity affect a wormhole as in does a wormhole have mass?
  • Is a wormhole fixed in space/time, example I have three wormholes (not connected) located in space time, do the relative distances/vectors change between the wormholes change because of the geometry differences of space/time at each location?
  • Can it be moved by some means?
  • If an object that is too large to enter the wormhole hit the wormhole what would happen to the object? Does the object break apart, just run past it, get a hole the size of the wormhole and only parts of the object will go through the wormhole?
Thanks in advance,
Michael.
There are no confirmed scientific models to predict the behavior of wormholes. This makes your work as a sci-fi writer both easier and harder.
Easier, since you can set the answers of your questions according to the requirements of your planned plot. (Existing physics is a limit of course, but beyond that you are quite free.)
Harder, since once you established your universe you have to obey its rules, even if it ruins your plot later on... This is really hard, but also gives the most fun.
If you give us your own answers we might be able to point out flaws and requirements, but who would dare to set rules for the universe of somebody else?
I will try to explain how I see wormholes, or hope to use them in the plot:
    A wormhole is a fixed position in space time. This means that a wormhole would not be affected gravity or other forces. I ran into a problem here as determining the position becomes rather hard. Everything else is moving with some kind of vector through space but there is no absolute position, but by setting a wormhole to a fixed position in space time the wormhole will be hard to position.
    Yes it should be able to move them but I don't know how.
    As a wormhole is essentially an alteration of the geometry of spacetime, I need to find some way to make the mathematics work in spacetime.
    I have two arguments:
    1: Normally spacetime is affected by mass/gravity. A wormhole shapes the geometry in space. So it must show as mass, a very big mass as it bends space into a shape not normally considered.
    2: Spacetime can have a geometry of its own. This can be a 'natural' geometry and therefore not caused by gravity. It simply is the straight path through spacetime.
    How this can be accomplished is beyond me for now. I don't like to introduce exotic matter or some meta abilities that reach beyond spacetime. I don't have a good idea if the relocation of a wormhole would require energy and if so how much (only an order would suffice).
    When an object that is too large to enter the wormhole it will allow the particles that fit through and the rest to follow its normal path through space. This will make a very perfect round tunnel through the object. The wormhole is simply a path in spacetime but with the restriction that it will not fit anything as its geometry doesn't allow bigger objects to pass through.
Thanks in advance,
Michael.
You can use the cosmic background radiation as stationary. That would be 630 km/s relative to the Milky Way. Alternatively you could use the Milky Way's center, The local group's center, or the Virgo super-cluster center. Might be simplest to put it in orbit around a star.
I assume a wormhole has two ends. One or the other could be fixed with respect to something. Or they could be averaged. Is there any reason why the two ends need to be balanced?
Rather than a fixed position you could set a fixed distance between the ends of the wormhole. As space expands the two holes would appear to fly towards each other.
Probably best to decide how the motion or position of the wormhole makes your story work. Then select the reason why that motion or position "needs to" have happened. Some of your characters understand the mechanics and the other ones trust her judgement.
... I don't have a good idea if the relocation of a wormhole would require energy and if so how much (only an order would suffice).
Stars can be moved around with Shkadov thrusters.
For a star such as the Sun, with luminosity 3.85 × 1026 W and mass 1.99 × 1030 kg, the total thrust produced by reflecting half of the solar output would be 1.28 × 1018 N. After a period of one million years this would yield an imparted speed of 20 m/s, with a displacement from the original position of 0.03 light-years. After one billion years, the speed would be 20 km/s and the displacement 34,000 light-years, a little over a third of the estimated width of the Milky Way galaxy.
The main problem with Shkadov thrusters is that your characters usually die of boredom a few hundred thousand years before reaching the speed of a brisk walk. If you use an asymptotic giant branch star instead of the sun you can get 1000 times higher thrust. So walking speed in 10 generations or so. Shkadov thrusters are believable and do not violate any laws of physics. The wormhole is probably in orbit with the star so the thrusters have to move both.
Recently, I’ve heard from Anton Petrov on YouTube that some tidally-locked planets around red-dwarf stars (such as TRAPPIST-1) have been suspected to flip around their own axis every once in a while — so that the former day side becomes the night side, and vice versa. This is presumed to happen for the same reason as why a T handle set in a rotating motion on a space station starts flipping back and forth. The latter is an issue we discussed for spaceship designs, when it came to how...
  • · Replies 49 ·
  • · Replies 22 ·
