Would light travel in a circle at the edge of the observable Universe?
The discussion revolves around whether light could travel in a circle at the edge of the observable universe, particularly in relation to the mass distribution and the concept of a black hole event horizon. Participants explore theoretical implications, mathematical calculations, and the nature of the observable universe.
  • Some participants question whether there is sufficient mass within the observable universe to create a black hole event horizon, with differing opinions on the answer.
  • Calculations regarding the Schwarzschild radius for a mass of 1.5*10^53 kg are presented, with some participants asserting its relevance while others argue it is not applicable in the context of the universe's expansion.
  • There is a discussion about the nature of the observable universe, with some participants suggesting that the "edge" of the observable universe is not uniform and depends on the observer's location.
  • Concerns are raised about whether the mass within the observable universe was ever enclosed within a radius that would correspond to a black hole at the time light was emitted from distant galaxies.
  • Some participants highlight that the universe's mass distribution is not conducive to defining a Schwarzschild radius meaningfully due to its uniformity.
  • There is a playful exchange regarding the concept of having one's own observable universe and the implications of such a notion.
Participants express multiple competing views regarding the sufficiency of mass to form a black hole event horizon and the relevance of the Schwarzschild radius in cosmological contexts. The discussion remains unresolved with no consensus reached on these points.
Participants note that the Schwarzschild radius is not synonymous with the event horizon in cosmological models, and that the assumptions about mass distribution and density in the universe complicate the application of these concepts.
Devin-M
Is there sufficient mass within the observable universe’s volume to form a black hole event horizon around the observable universe and, if yes would light fired tangentially at the edge of our observable universe ever loop back around in a circle or spiral inwards?
Astronomy news on Phys.org
No.
No.
For an ordinary mass of 1.5*10^53 kg then the Schwarzschild radius would be 2.2*10^26 m, is that correct?
The Schwarzschild radius isn't really relevant here. The event horizon is only at the Schwarzschild radius for a non-rotating black hole. And light doesn't do circular orbits at the event horizon anyway.
Furthermore, an FLRW spacetime is the same everywhere, so light at the edge of the observable universe would have to orbit every point at the appropriate distance at the same time. That doesn't make sense.
Wouldn't the edge of the observable Universe depend on where you are in the Universe?. In other words, the "edge" we can see is not the same edge as an observer 10 billion light years away can see.
Yes, which is perhaps a clearer way of getting at what I was trying to say in #4.
So at the time the light from the farthest galaxies we can observe was emitted, the mass we can see within the observable universe wasn’t enclosed within that radius?
There are several previous threads that explain why the early universe was not a black hole. Which I assume is the question that you posed cryptically in your original post?
I must have missed those threads can you post a link? I’m confused because for 13.8 billion light years I get a radius of 1.3*10^26 m and for a mass of 1.5*10^53 kg I get a Schwarzschild radius of 2.2*10^26 m.
Yeah, but it's not relevant. Schwarzschild radius and event horizon are not synonymous except in Schwarzschild spacetime, which the large scale universe is almost completely unlike. You can't even define an event horizon in the cosmological FLRW spacetime (at least in the sense of a black hole event horizon - there is an unrelated thing with the same name, unfortunately).
Not only that, but technically, if you were standing next to me we would each have our own observable universes (with essentially total overlap but technically not exactly the same)
That's cool. I've never had my own observable universe before. First thing I need is a suitable title, then there are going to be some changes around here.
  • Haha
"Lord of all I survey except the bits others survey too"? There's a lot of volume out there, but there's not a lot in it...
Not bad. But "Lord" seems a bit over used to be honest and not nearly majestic enough. Also, I won't be doing any surveying, I have minions for that.
Had the most distant observable stars & galaxies formed while still within a volume less than the Schwarzschild radius for the combined mass within that volume at the time?
How could that possibly be the case?
I thought at the time the light was emitted by the most distant galaxies we can see, they were less than 13.8 billion light years distant from us (less than 1.3*10^26 m) and for a mass of 1.5*10^53 kg (the normal mass of the observable universe) I get a Schwarzschild radius of 2.2*10^26 m.
You are talking about a situation where a large mass is surrounded by a MUCH less dense area. That's not the case with the universe. What is now the observable universe was just a part of a huge (possibly infinite) fairly uniform mass, so there was no center around which a Schwartzchild radius would be meaningful.
You may be right. The Schwarzschild radius increases linearly with mass; whereas, the radius of something massive increases with the cube root of the mass. Eventually, if you have a large enough volume of low density matter in a homogeneous universe, then you must exceed the Schwarzschild radius at some volume.
I must admit I never thought of it that way.
The Schwarzschild radius of the Sun is only 3km and that of the Milky Way is about one light-year. But, if you take a large enough volume of galaxies, then you do exceed the Schwarzschild radius for the total mass.
The same proviso applies that the Schwarzschild radius is not relevant for an expanding universe.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 17 ·
