Write each polynomial as the product of it's greatest common
  • Thread starter Thread starter MathJakob
    Polynomial Product
The discussion focuses on factoring polynomials by extracting their greatest common monomial factors. Participants analyzed the polynomials 8x² + 12x and 6a⁴ - 3a³ + 9a², determining that the greatest common monomial factors are 4x and 3a², respectively. The conversation highlighted the ambiguity in the problem statement regarding whether to factor to integer coefficients or allow fractions. Ultimately, the consensus is that for Algebra II contexts, integer factorization is preferred, and the simplest forms of the factorizations are 4x(2x + 3) and 3a²(2a² - a + 3).
  • Understanding of polynomial expressions and their components
  • Knowledge of greatest common factors (GCF)
  • Familiarity with factoring techniques in algebra
  • Basic algebraic manipulation skills
  • Study polynomial factorization techniques in detail
  • Learn about the significance of integer coefficients in algebraic expressions
  • Explore the concept of greatest common divisors in polynomial contexts
  • Practice factoring a variety of polynomials to reinforce skills
Students studying algebra, particularly those in Algebra II or self-learners interested in mastering polynomial factorization techniques.
MathJakob
Write each polynomial as the product of it's greatest common monomial factor and a polynomial
8x^2+12x
6a^4-3a^3+9a^2
4x(2x+3)
a^2(6a^2-3a+9)
I really don't understand what it's asking me for, how can I factor this more?
The second equation can be factored a little further. The three terms still have one more common factor.
Are these two separate problems? It sounds like it just wants you to factor out the greatest common factor.
4x(2x+3) I can't see anymore common factors...
a^2(6a^2-3a+9 also has no common factors, if it were a +3 instead of a -3 then I could do this 6a^4-3a^3+9a^2
3a^2(2a^2-a+3)
hmm can you give me a pointer? I assume I have to get rid of the remaining squares?
What about ##8x(x + 3/2)##? No one said anything about needing the polynomial factor to have integer coefficients. The question is ambiguous; I would skip it.
One more thing, if x is negative, the factor 4x is smaller than the factor 2x.
I disagree with verty about 8x(x+ 3/2) being a solution. In factoring problems, it is generally understood that the coefficients are to be integers in order to have a unique solution.
a^2(6a^2-3a+9) also has no common factors, if it were a +3 instead of a -3 then I could do this 6a^4-3a^3+9a^2
3a^2(2a^2-a+3)
I have no idea what "+3" or "-3" you are talking about. 3a^2(2a^2- a+ 3) is a perfectly good solution to the original problem.
"Write each polynomial as the product of it's greatest common monomial factor and a polynomial"
So this answer satisfies the original question?
That should do it. The negative doesn't make a difference in this case for the purposes of factoring. What's important is that the two expressions remain equal. If you now distribute the 3a^2 back into the parentheses, you will end up with exactly the same expression as the original problem. You just have to make sure to keep your signs straight when you're factoring.
I'd also agree that it should remain in integer form. Typically, "simplest form" of an expression is going to involve integer coefficients. There's no rule that you can't factor fractions out, but in general, you don't unless you have to.
I agree with verty. If the question doesn't specifically state that you want to factor it as integer polynomials, then any factorization goes. A question should state this.
I agree. A fractional factorization certainly wouldn't be "wrong." However, for simplicities sake, I'd imagine a factorization with integer coefficients would be preferred.
You could take it further though.
6a^4-3a^3+9a^2
3a^2(2a^2-a+3)
From this point, you could still factor a 2 out.
6a^2(a^2-\frac{1}{2}a+\frac{3}{2})
But, that strikes me as unnecessary.
I am quite sure that the solution is supposed to have integers only.
Even more, I don't think those other proposed ideas are solutions: They assume an additional structure which is not given in the problem statement. You can study polynomials outside of real and complex numbers. It could be that 1/2 or 1/3 are not even well-defined there.
Although I agree, I think the problem statement should have clarified this. Right now we're only guessing.
If you are asked to factorize 12, do you write it as 12=2*2*2*3*(1/2) or 12=2*2*2*(3/2)?
It's rather clear that we work in the integers there. If we work with polynomials, then it is not at all clear to me where we work in. There are many very natural rings to work in. Unlike factorizing 12, where there is really only one interesting ring.
I agree that they are likely just asking for integer factorization. It's the simplest and clearest factorization of the given polynomials.
We could factor another 2 of it from this point...
12a^2(\frac{1}{2}a^2-\frac{1}{4}a+\frac{3}{4})
But, that seems unnecessary, and we could continue taking it infinitely further if we wanted...but that seems silly, given the problem statement.
What class is this for? If it's a pre-calc algebra class, it's likely safe to assume that they're asking for integer factorization.
I apologize, I didn't see the significance of the word "common" in "greatest common monomial factor", I read it as "greatest monomial factor common to each term", equivalent to "greatest monomial factor", equivalent to "greatest monomial that divides evenly". On this reading, the question seemed vague to me.
If it had said "greatest common monomial divisor", I would have seen the connection. I would have assumed that the coefficient of the monomial is the GCD of the coefficients and the index is the minimum of the indices.
It isn't for any class, it's just from a Algebra II + Trig eBook that I'm studying from. I'm learning math by myself as a hobby.
Gotcha. Within the context of algebra II, we can basically be certain that they're asking for integer factorization. The Greatest Common Monomial Factor would imply the greatest factor that is common to all of the terms in the given polynomial. In the case of the first expression, the greatest common monomial factor is 2x, and in the second expression, it is the 3a^2
  • · Replies 24 ·
  • · Replies 27 ·
