Writing a matrix as sum of a constant * matrix
To determine if a matrix A can be expressed as A = xB + yC, where B and C are known matrices and x and y are constants, one must set up a system of equations based on the matrix entries. This involves equating A to the linear combination of B and C, resulting in a system of equations that can be solved for x and y. If the system has a solution, it indicates that such constants exist; if not, they do not. The complexity of the matrices, such as 10x10 dimensions, does not hinder the process significantly, as only a few equations are needed to find the solution. Ultimately, the existence of x and y depends on the relationship between the matrices involved.
2slowtogofast
Ok I need some help on how I can approach a problem like this.
Say that A B and C are matircies and I know the values of each of them.
And let x and y be constants (ie: 7 or 2 or somthing like that)
What I want to know is can you write
A = xB + yC
How would you check to see if there are an x and y that can make that equation true and if there is how can you find it. I think if B and C are in the span of A then yes there is an x and y but that doest tell me how to find them.
You can check if there are x and y that make the equation true by solving the system of equations generated by matrices.
Let matrix A be A=\left| \begin{array}{cc} a_{11} & a_{12} \\ a_{21} & a_{22} \end{array} \right|, and B B=\left| \begin{array}{cc} b_{11} & b_{12} \\ b_{21} & b_{22} \end{array} \right|. Matrix C will be C=\left| \begin{array}{cc} c_{11} & c_{12} \\ c_{21} & c_{22} \end{array} \right|.
You get the system of equations to solve for x and y with the following expression:
\left| \begin{array}{cc} a_{11} & a_{12} \\ a_{21} & a_{22} \end{array} \right| - x \left| \begin{array}{cc} b_{11} & b_{12} \\ b_{21} & b_{22} \end{array} \right| - y \left| \begin{array}{cc} c_{11} & c_{12} \\ c_{21} & c_{22} \end{array} \right| = \left| \begin{array}{cc} 0 & 0 \\ 0 & 0 \end{array} \right|.
I was thinking of that as well the only problem is what if A B and C are 10 x 10 it would work but it is a lot of work. Is there a more effcient method.
Well, you need just a few equations to solve the system, so it doesn't matter if a matrix is 10 x 10. It wouldn't take too long. As far as I know, there is no more efficient method. Today, if we want to deal with 100 x 100 matrices, we use computers. That's why we've made them in the first place. :-)
in your first post how would you expand that to a system of 2 eqns and 2 unkwns. The 2x2 constant matrix is what is screwing me up
You don't expand an equation with two by two matrices into a system of two equations. An equation involving two by two matrices is equivalent to a system of four equations, one for each of the four entries in the matrices. In general, you cannot solve an equation like "A= xB+ yC" for number x and y given matrices A, B, and C unless A, B, and C are carefully chosen, just as you cannot solve four equations in two unknowns unless the equations are "dependent". In general, there simply do NOT exist such numbers.
Isn't the solution of the system we get an indicator of the existence of those numbers? If the system has a solution, such x and y exist. Otherwise, they don't.
  • · Replies 33 ·
  • · Replies 52 ·
  • · Replies 16 ·
