##x\lt y \lt z## positive integer numbers and if ##\dfrac 1x+\dfrac 1y+\dfrac 1z=\dfrac 13##
  • Context: Undergrad
  • Thread starter Thread starter littlemathquark
The discussion revolves around the diophantine equation ##\dfrac 1x+\dfrac 1y+\dfrac 1z=\dfrac 13##, specifically focusing on finding the positive integer solutions for the variables ##x, y, z## under the condition that ##x < y < z##. Participants explore methods for determining the minimum and maximum values of the sum of these variables, as well as algorithms that could assist in finding these values.
  • Some participants propose that finding individual values of ##x, y, z## is necessary to determine the minimum and maximum sums.
  • Others mention that there exists an algorithm that can yield the minimum and maximum sums, citing that there are ##15## solutions with minimum ##31## and maximum ##173##.
  • A participant suggests that the algorithm used by Wolfram Alpha (WA) likely involves reducing the problem to a two-dimensional lattice problem.
  • There is a discussion about whether an algorithm can directly output specific values for the minimum and maximum sums, with references to a particular algorithm that may produce maximum denominators.
  • A detailed solution approach is presented by one participant, outlining steps taken to derive possible values for ##x, y, z## and the conditions under which they hold.
  • Another participant challenges the number of solutions, indicating that the condition ##0 < x < y < z## implies there are fewer than ##21## solutions.
  • There is a clarification regarding the ordering of the variables, with one participant stating they solved for ##x \ge y \ge z \ge 0##.
Participants express differing views on the number of solutions and the conditions under which they apply. There is no consensus on the exact number of solutions or the best method for finding them, indicating ongoing debate and exploration of the topic.
Some assumptions regarding the ordering of variables and the implications for the number of solutions remain unresolved. The discussion also highlights dependencies on specific algorithms and their effectiveness in solving the problem.
littlemathquark
TL;DR
İf ##x\lt y \lt z## positive integer numbers and if ##\dfrac 1x+\dfrac 1y+\dfrac 1z=\dfrac 13## then find the minumum and maximum value of sum of ##x+y+z##
I can solve diophantine equation of ##\dfrac 1x+\dfrac 1y+\dfrac 1z=\dfrac 13##. But do I have to find the individual values of x, y, and z to find the minimum and maximum value of the sum? Isn't there an algorithm that gives the smallest and biggest sum of denominator values?
Mathematics news on Phys.org
Well, there is an algorithm. WA says that there are ##15## solutions, with ##31## being the minimum and ##173## the maximum. it looks as if they eliminated ##z## and solved the remaining two-dimensional lattice problem.
Observation: ##3\,|\,xyz## and looking at the results, we see that ##3\,|\,z.## Could be a point to start with.
Well, I didn't mean that. I was asking if there's an algorithm that can directly output the values for the minimum as ##1/3 =1/6+1/10+1/15## or for the maximum as ##1/3=1/4+1/13+1/156##
İn fact I know algorithm ##1/x=(1/x(x+1)) +(1/(x+1))## and I think it's produce maximum denominators.
İn fact I know algortihm ##1/x=(1/x(x+1)) +(1/(x+1))## and I think it's produce maximum denominators.
Yes, and I answered your question. There exists an algorithm simply because WA uses one. I don't know which one, but I suggested a reduction to a lattice problem. Look up lattice algorithms.
Here is a starting point:
https://sites.math.washington.edu/~rothvoss/lecturenotes/IntOpt-and-Lattices.pdf
My solution like this: I solved for ##x\ge y\ge z##
İt's clear ##x,y,z >3##
Let ##x\leq y\leq z##. Then ##\frac{1}{z} \leq \frac{1}{y} \leq \frac{1}{x}## and ##\frac{1}{3} = \frac{1}{x} + \frac{1}{y} + \frac{1}{z} \leq \frac{3}{x}##, ##x \leq 9## that is ##4\leq x \leq 9##
İf ##x=4## then ##\frac{1}{3} = \frac{1}{4} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{1}{12} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##, ##y\leq 24##
##\frac{1}{z} = \frac{y-12}{12y}##, ##z=\frac{12y}{y-12} = 12+\frac{144}{y-12}##
##13 \leq y \leq 24##
##(x=4,y=13, z=156), (x=4,y=14, z=84), (x=4,y=15, z=60), (x=4,y=16, z=48) (x=4,y=18, z=36), (x=4,y=20, z=30),(x=4,y=21, z=28),(x=4,y=24, z=24)##
if ##x=5## then ##\frac{1}{3} = \frac{1}{5} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{2}{15} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##, ##y \leq 15##
##\frac{1}{z} = \frac{2y-15}{15y}##, ##z=\frac{15y}{2y-15} = 7+\frac{y}{2y-15}##
##8 \leq y \leq 15##.
##(x=5,y=8, z=120), (x=5,y=9, z=45), (x=5,y=10, z=30), (x=5,y=12, z=20),(x=5,y=15, z=15)##
if ##x=6## then ##\frac{1}{3} = \frac{1}{6} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{1}{6} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##
##y \leq 12##
##\frac{1}{z} = \frac{y-6}{6y}##, ##z=\frac{6y}{y-6} = 6+\frac{36}{y-6}##
##7 \leq y \leq 12##.
##(x=6,y=7, z=42), (x=6,y=8, z=24),(x=6,y=9, z=18),(x=6,y=10, z=15),(x=6,y=12, z=12)##
if ##x=7## then ##\frac{1}{3} = \frac{1}{7} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{4}{21} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##
##y \leq 10##
##\frac{1}{z} = \frac{4y-21}{21y}##, ##z=\frac{21y}{4y-21} = 5+\frac{y+105}{4y-21}##
##7 \leq y \leq 10##.
##(x=7,y=7, z=21)##
if ##x=8## then ##\frac{1}{3} = \frac{1}{8} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{5}{24} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##
## y \leq 9##
##\frac{1}{z} = \frac{5y-24}{24y}##, ##z=\frac{24y}{5y-24} = 4+\frac{4y+96}{5y-24}##
##8 \leq y \leq 9##.
##(x=8,y=8, z=12)##
if ##x=9## then ##\frac{1}{3} = \frac{1}{9} + \frac{1}{y} + \frac{1}{z} ##, ##\frac{2}{9} = \frac{1}{y} + \frac{1}{z} \leq \frac{2}{y}##
##y=9##
##(x=9,y=9, z=9)##
There is ##21## solutions.
You said ##0<x<y<z##, so there are fewer than 21 solutions.
Yes, I solved
for ##x\ge y\ge z\ge 0##
  • · Replies 60 ·
13K
  • · Replies 61 ·
12K
