shooride
- 34
- 0
Can one define a vector space structure on a Riemannian manifold ##(M,g)##?! By this I mean, does it make a sense to write ##x+y## where ##x,y## are arbitrary points on ##M##?
The discussion centers on the possibility of defining a vector space structure on a Riemannian manifold ##(M,g)##, specifically whether it makes sense to perform operations like ##x+y## for arbitrary points ##x,y## on ##M##. Participants explore both local and global implications of such a structure, touching on concepts from differential geometry and topology.
Participants generally disagree on the feasibility of defining a global vector space structure on a Riemannian manifold, with some asserting it is impossible due to topological constraints while others suggest local definitions may be possible.
Limitations include the dependence on local coordinate systems and the potential for singularities in the exponential map, which complicate the definition of vector operations on the manifold.
shooride said:Can one define a vector space structure on a Riemannian manifold ##(M,g)##?! By this I mean, does it make a sense to write ##x+y## where ##x,y## are arbitrary points on ##M##?
micromass said:No. But do check out the exponential map for something close to what you're attempting.
Yes, that is a harder question, I don't know if it can be done or not.micromass said:Locally sure, but I guess he means a global vector space structure.
WWGD said:Yes, that is a harder question, I don't know if it can be done or not.
But isn't vector space structure independent of topology ( if you ignore the inner-product generating a norm and "inducing" a normed space/vector space structure)?micromass said:It can't. There are topological obstructions.
Sorry, I don't get your point. Do you mean there is no compatibility as _normed spaces_ , alone, tho there is as pure vector spaces? Could you cite the topological obstruction?micromass said:In that case, every manifold has the same cardinality of ##\mathbb{R}##, so you can find a bijection.
micromass said:The topological construction is contractibility.
If you don't care for topology, then you can find a bijection and then just transport the structure.
I couldn't get your point on this quote..how can one define the distance on M?!WWGD said:I don't think (at least I don't see how) the Riemannian metric here plays a role.
Yeah.. I think things are starting to be a bit clearer .. however, I couldn't understand what does really a Riemannian vector space look like?!lavinia said:Here is an exercise. Prove that a manifold that is a vector space over the real numbers is diffeomorphic to Rn.
- If you only require addition and not scalar multiplication, then the manifold is called a Lie group. If the addition is commutative, then the manifold can be an n dimensional torus.
Your question will not work if you replace vector space by Lie group. The condition of being a Lie group is very restrictive. For instance the only closed 2 dimensional surface that is a Lie group is the torus.
shooride said:Yeah.. I think things are starting to be a bit clearer .. however, I couldn't understand what does really a Riemannian vector space look like?!
I'm interested in a Riemannian manifold in which ##x+x'## and ##\alpha.x## where ##\alpha## is a scalar from some field have a meaningful definition..so I thought that this kind of riemannian manifold should has an additional vector space structure..if I understand it correctly, one can locally consider it..lavinia said:Not sure what you mean by Riemannian vector space - but Rn together with an inner product is a Riemannian manifold that is also a vector space. Algebraically, one sees the connection between geometry and vector algebra through the bilinearity of the inner product.
Geometrically, the inner product assigns lengths to vectors and angles to pairs of vectors. Without the inner product there is no geometry.
- Technically, a Riemannian metric is defined on the tangent bundle of the manifold. But in Rn the tangent space and the vector space are canonically identified.
shooride said:I'm interested in a Riemannian manifold in which ##x+x'## and ##\alpha.x## where ##\alpha## is a scalar from some field have a meaningful definition..so I thought that this kind of riemannian manifold should has an additional vector space structure..if I understand it correctly, one can locally consider it.. normal coordinates doesn't mean the same thing?!
The distance is dealt with by treating ##(M,g)## as a length space: the distance between two points equals the length of the shortest path between the points.shooride said:I couldn't get your point on this quote..how can one define the distance on M?!
What it comes down to is this: You want your n-manifold to be a finite-dimensional (n -dimensional) inner-product space, with the inner-product given by the Riemannian metric. But there is a result that every finite-dimensional normed space (over a fixed field) of dimension n is isomorphic to ##\mathbb R^n ## . This means your manifold, if given an inner-product normed space condition, will have to be homeomorphic to ## \mathbb R^n ##, since the (metric) topology generated by the norm will be homeomorphic to that of ##\mathbb R^n ##.shooride said:Yeah.. I think things are starting to be a bit clearer .. however, I couldn't understand what does really a Riemannian vector space look like?!
Depending on what you really mean by this question, there are various answers. (Though it is not clear how you might want the Riemannian structure to relate, if at all, to the vector space structure.)shooride said:Can one define a vector space structure on a Riemannian manifold ##(M,g)##?! By this I mean, does it make a sense to write ##x+y## where ##x,y## are arbitrary points on ##M##?
