Y=ln(3-x) How to transform it? What is wrong with my logic?
  • Thread starter Thread starter J_Ly08
    Logic Transform
The discussion revolves around understanding the transformation of the function y = ln(3-x). The user initially graphed ln(-x) and attempted to shift it left by 3, but this approach was incorrect. The correct transformation involves reflecting the graph of y = ln(x) across the y-axis to get y = ln(-x), followed by translating it right by 3 units to yield y = ln(-(x - 3)). The confusion arises from misinterpreting the transformation steps, as ln(3-x) does not equate to simply moving ln(-x) left by 3. Clarification on these transformations helps in grasping the correct graph behavior.
J_Ly08
Hi, my name is Tim, I am new to this forum. Here's the description:
I don't understand how they've done it. I realize I can plot this, but what is the logic.
As a graph, I drew ln(-x) first, then added 3, so move left by 3 but that was not correct
I can see they've added 3 first, move left 3. Then they minus 1 times x. Or have they done it another way?
Why wasn't the first one correct, it makes sense to me
I also tried another approach which was ln(-(x-3)) so I first drew ln(x-3), and then I minus 1 times x, so I flipped it against the y axis. That also did not work, what is wrong with the logic on this one as well?
Mathematics news on Phys.org
I really don't understand. The graph of \ln(3-x) is the curve which has exactly the same shape as \ln x, only that it is "crosses" the Ox axis in x=2 and diverges rapidly to -\infty in x=3.
In other terms, it the graph of \ln -x (which you get from the graph of \ln x by rotating it around the Oy axis) shifted rightwards on the Ox axis by 3 units.
Thanks for the reply. Can you please explain/reword
In other terms, it the graph of ln−x (which you get from the graph of lnx by rotating it around the Oy axis) shifted rightwards on the Ox axis by 3 units.
I'm looking at it as transformation, so just like y=(x^2 + 3) moves x^2 up 3 units. Why isn't y=ln(3-x) moving ln(-x) 3 times to the left? and also to the last part of my question of my first post, if you write it as ln(-(x-3)) why wouldn't that work?
much appreciate for the help
Why not? Because ln(3-x) is not the same as (ln(-x)) - 3
You should be able to show, viewing it as the sum of two logarithms,
ln(-x) - 3 = ln( (-x) / (e³) )
Here's why.
Basic function: y = ln(x)
Reflection across y-axis: y = ln(-x)
Translation: y = ln(-x + 3) = ln(-(x - 3))
Notice that this is a translation to the right by 3 units of the graph of y = ln(-x).
Draw the basic untransformed graph, y = ln(x)
Reflect across the y-axis to get y = ln(-x)
Translate right by 3 units to get y = ln(-(x - 3)
On the first graph, one point is (1, 0).
On the reflected graph, this point moves to (-1, 0) [Check: ln(-(-1)) = 0]
On the translated graph, this point (in previous step) moves to (2, 0) [Check: ln(-(2 - 3)) = ln(-(-1)) = ln(1) = 0.
Thanks for the responses.
After reading mark's reply its starting to clear up more. Much appreciate the help :)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
