The discussion revolves around calculating the current through a resistor in a parallel circuit, given the e.m.f. and internal resistance of the power source. Participants are exploring the relationships between total resistance, current, and voltage drops in the context of parallel resistors.
- Exploratory, Conceptual clarification, Mathematical reasoning
- Participants discuss calculating total resistance and current, with some questioning whether the e.m.f. should be considered the supply voltage. Others suggest using the internal resistance in conjunction with the e.m.f. to find terminal voltage and current through the resistors.
The discussion is active, with participants offering various approaches to the problem. Some guidance has been provided regarding the use of e.m.f. and internal resistance, but there is no explicit consensus on the best method to proceed.
Participants are working under the constraints of a homework assignment, which may limit the information available or the methods they can use to solve the problem.
