Calculating Young's Modulus with Force and Extension Measurements
To calculate Young's Modulus from the provided force and extension measurements, the formulas for stress (σ = F/A) and strain (ε = e/l) are essential. The area is specified as 50mm by 5mm, which is needed to determine stress. Young's Modulus (E) can be calculated using E = σ/ε or E = (F*l)/(A*e), where F is the force, l is the original length, A is the cross-sectional area, and e is the extension. It is suggested to plot a graph of force versus extension to visualize the relationship and determine the slope, which represents Young's Modulus. The calculations and graphing will help clarify which data points to use for accurate results.
ACCC12
hi
i have been given these results in order to work out the young's modulus can any 1 tell me how i go about doing this
Force (kN) Extension (mm)
0.5 0.003
1 0.011
1.5 0.019
2 0.021
2.5 0.024
3 0.032
3.5 0.040
4 0.043
4.5 0.050
5 0.060
5.5 0.064
6 0.070
6.5 0.076
7 0.081
Area 50mm by 5
thanks for all your help
E=\frac{stress}{strain}
Write the formula for stress and the formula fopr strain and then simply the formula for Young's Modulus,E.
i know the equation but i didnt know which part of the data to use, do i just take any part of the data from the table or do i have to plot a graph! thanks for all you help!
what is meant by "area 50mm by 5 " in your data ? please explain.
E=\frac{\frac{F}{A}}{\frac{e}{l}}
E=\frac{Fl}{Ae}
Right?
From your graph, what does the fraction F/e represent?
50mm length, 5mm diameter
got the answer to be 5.3 is that correct!
equation used
2.5 x 50
981.75 x 0.024
any takers! thanks
