Zeroth component of Spin 4-Vector
The zeroth component of the spin 4-vector is zero in the rest frame of a particle because it represents the spatial direction of the particle's spin axis, which must be orthogonal to the particle's 4-velocity. In this frame, the 4-velocity is (1, 0, 0, 0), enforcing that the zeroth component of the spin 4-vector must also be zero. The spin 4-vector can be viewed as the expectation value of the quantum mechanical spin or as the spin of a gyroscope, defined along the world-line of the particle. This framework allows for the definition of a 2-form that quantifies angular momentum about an instantaneous axis in the center of mass frame. The discussion emphasizes the conceptual and mathematical foundations of the spin 4-vector in relativistic contexts.
thebiggerbang
The spin 4-vector is defined in the rest frame of the particle as s^{\mu}= (0, \vec{s}).
Why is the zeroth component of the same zero in this frame?
Because the whole point of defining the spin 4-vector is to represent the spatial direction of the particle's spin axis. That spatial direction, like any spatial direction relative to the particle, must be orthogonal to the particle's 4-velocity ##u^{\nu}##, i.e., ##\eta_{\mu \nu} s^{\mu} u^{\nu} = 0##. Since the components of ##u^{\nu}## in the particle's rest frame are ##(1, 0, 0, 0)##, that forces the zeroth component of ##s^{\mu}## to be zero in that frame.
Note that all of this is assuming that the concept of a "spin 4-vector" makes sense; the thread stevendaryl linked to discusses a number of significant limitations of that concept.
##S^{\mu}## is the spin 4-vector along the world-line of a given observer or particle with 4-velocity ##u^{\mu}##. It can be the expectation value of the quantum mechanical spin of a particle but it's easier conceptually to think of it as the spin of a gyroscope or of some extended body whose characteristic size is much smaller than the characteristic length scale of curvature. In this case ##u^{\mu}## belongs to the world-line of the center of mass of the extended body. The body itself defines a small world-tube around the center of mass world-line. Using axial Killing field symmetry considerations of the world-tube and the energy-momentum tensor of the body with compact support on the world-tube, we can define a 2-form ##S_{\mu\nu}## that quantifies the angular momentum or spin of the body about an instantaneous axis, as measured in the center of mass frame i.e. in the instantaneous rest frame of ##u^{\mu}##. This is also the canonical frame one would pick in Newtonian mechanics when calculating angular momentum (recall those ever-fun non-slipping rolling sphere problems).
The details of the construction of ##S_{\mu\nu}## are rather involved. An extremely detailed exposition can be found in chapter 7, and specifically section 7.3, of "Relativity on Curved Manifolds"-de Felice and Clarke. If you can't access the book then see here: http://arxiv.org/pdf/1103.0543v4.pdf
Once we have ##S_{\mu\nu}## it is natural to define the axial 4-vector ##S^{\mu} = \epsilon^{\mu\nu\alpha\beta}u_{\nu}S_{\alpha\beta}##. Clearly then ##S^{\mu}u_{\mu} = 0## which in the center of mass frame, or in the instantaneous rest frame of a comoving gyroscope in the limit as the size of the extended body goes to zero, we have ##S = (0, \vec{S})##.
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 17 ·
11K
  • · Replies 0 ·
