How Does Copper Sulfate Affect the Reaction Between Zinc and Hydrochloric Acid?
  • Thread starter Thread starter flumbie
    Acid Zinc
The discussion centers on the reaction between zinc, hydrochloric acid, and copper sulfate, particularly focusing on the role of copper ions as a catalyst. It is clarified that zinc is oxidized to zinc ions while reducing copper ions to solid copper. The resulting copper can coat the zinc, creating an electrolytic cell where zinc acts as the anode and copper as the cathode, with hydrochloric acid serving as the electrolyte. This setup enhances the rate of hydrogen production by facilitating the reduction of hydrogen ions at the cathode. Although copper does not revert to copper ions at the end of the reaction, this does not significantly impact the overall reaction rate. The conversation also addresses misconceptions about the necessity of copper ions as a catalyst and emphasizes that zinc reacts effectively with hydrochloric acid on its own.
flumbie
I'm having some trouble understanding what happens when Zinc and Hydrochloric acid are reacted with Copper Sulfate as a catalyst. I *think* the Copper ion gets electrons from the zinc and turns into straight copper which leaves zinc free to react with the chlorine to form zinc chloride. Does this affect the rate at which hydrogen are formed because the electrons are going from the zinc to the copper instead of from the zinc to hydrogen? Any help much appreciated.
Chemistry news on Phys.org
bumped
Does no one know or do you just not want to tell me?
i guess this is what happens...
the Cu++ is reduced by zinc to Cu and the zinc is oxidised to Zn++. the Zn++ reacts with the Cl-.
the Cu is then oxidised back to Cu++ by H+ which gets reduced to H2
overall reaction: Zn + 2HCl -----> ZnCl2 + H2
This do really happens, and quite fast, even without HCl, in water, so it's certainly one of the possible reactions.
Zn++ don't react with Cl- in water solution, and Cu cannot be oxidated from H+ in the absence of strong complexants of Cu++. Don't know what really happens but that explanation is not correct.
Certainly.
To flumbie: are you sure it was Zn, HCl and CuSO4?
Zn, HCl and CuSO4 works, i remember my teacher saying it.
and of course ZN++ does not REACT with Cl-, the ions remain in solution because ZnCl2 is a strong electrolyte.
but there has to be a way for Cu to get back to Cu++ and H+ to get to H2.
chemisttree heeelp!
It does certainly work, but is there really the need of Cu++ as catalyst? If I remember correctly, Zn should react quite fast even with HCl only.
chemisttree heeelp!
It's actually a pretty slow reaction (using 3M HCl at least).
found out how it works
Its not the Cu++ that's the catalyst its actually Cu. The copper ions in the CuSO4 are reduced by zinc which provides a coating of copper to cover the zinc. An electrolytic cell is made where the more reactive metal (Zn) is the anode and Cu is the cathode, with the HCl acting as an electrolyte. This means the hydrogen ions are more likely to be reduced at the cathode which results in a faster reaction rate. The Cu doesn't change back to Cu++ at the end of the experiment which does meant that slightly less hydrogen will be produced however this shouldn't affect the rate of the experiment overly much.
Thanks for the help anyway
And thanks to you to have explained this, it's something interesting I was not aware of. I'm sorry we couldn't help you and I hope you will keep asking interesting questions and that we could help you, next time!
Regards.
yeah... thank you for posting the actual mechanism :)
  • · Replies 26 ·
