Race car suspension Class
The discussion revolves around the intricacies of race car suspension design, particularly for stock cars and formula cars. Participants explore various technical aspects such as roll center, instant center, suspension geometry, and the effects of body roll on tire performance. The conversation includes both theoretical considerations and practical applications relevant to race car handling and performance.
  • One participant emphasizes the importance of understanding roll center height and its impact on weight distribution during cornering, noting that a lower roll center increases vertical loading on tires.
  • Another participant discusses the need for body roll to effectively transfer weight to outside tire contact patches, suggesting that improper weight transfer can lead to loss of grip.
  • Several participants propose various factors affecting suspension design, including kingpin inclination, scrub radius, camber, caster, and toe-out settings.
  • There are discussions about the significance of instant center width and how it influences roll center behavior during body roll, with some suggesting that a narrow instant center width can lead to more radical changes in tire loading.
  • One participant outlines a detailed approach to designing suspension mounting points, including specific measurements and angles that must be calculated to achieve desired performance characteristics.
  • Another participant expresses interest in exploring wheel rates and spring selection in future discussions, indicating a desire for deeper technical insights.
Participants generally agree on the importance of various suspension parameters and their effects on race car performance. However, there are multiple competing views on the optimal configurations and the implications of different design choices, leaving the discussion unresolved in certain areas.
Participants reference specific software tools and literature for suspension analysis, indicating that practical application may depend on access to these resources. Additionally, some discussions involve assumptions about vehicle design that may not apply universally across different race car types.
  • #301
Rick and Sierra, both have questions about rear end set up..
see post # 132 page 9 for 4 link info, post 116 page 8 for rear steer, post 81 page 6 for top link info, post 253 page 16 for 3rd link info and post 261 page 17 for 3rd link spring rate
now about the questions from Rick..we want the angles of the stock 4 link to form an Instant Center (IC) as far forward as possible. this longer lever cushions the acceleration when the tires hook up. Too short an IC distance means we have a lot of angle change on both sides and the car will be real darty when you nail it. Longer is better and gives the driver more control because you don't have a lot of angle change as the shorter IC has. I like your thinking about the rear steer since you are on asphalt and do not have a lot of body roll. You and tune with lower RC but we do not need bandaids..we need a set up to handle the weight transfer and kick enuff weight rearwards on turn exit to hook up. Have you calculated the total weight transfer to the front?
Sierra,,welcome ..please look up the posts and let us discuss your set up once you have looked them over..i am working on post for rear coikl over mounts..but have to make beer run first
RM
  • #302
I was reading some info on other sites regarding rear anti squat percentages..
Looks like front anti dive also plays a factor...(?)
Things were so much simpler before I found all these things...lol
Should I post what seems relevant?
  • #303
Hey Ranger
Looking at rear instant center height and location ?
where is a good starting point for height and location ie. transmission ,engine or between the front tires.
thanks smokin
  • #304
coil over location
Rear coil-overs should be mounted at angle between 13 and 20 degrees. If you can measure the max body roll, mount the shock so they are pushing straight up and down at this point. I did not realize it but coil-overs can effect weight transfer if not mounted properly. I the top of the coil-overs ( this applies to shocks as well) are mounted too high on the chassis they will hinder weight transfer. The top of the coil-overs should be mounted as close as possible or below the Center of Gravity Height. ( Rear CGH ball park 10 to 12 ") Most common is 9 inch stroke shock and what we do not want is to run out of travel. Try to mount the bottom of the coil-overs as low as possible under the axle center line. I think 7 inch is about the lowest you can go before you start to spark the asphalt. Don't forget if you cut a tire you don't want to screw up mounts and chance losing the mount for that race. This bottom mount location helps forward bite during acceleration. When you nail it off the turn, the weight is thrown from front to rear and is resisted by the coil-overs top mount. If you have the top mount higher than the Center of Gravity Height, the weight transfer loads the suspension links and not the coil-overs where it can assist forward bite. Same applies to shocks and coil springs.
  • #305
Rick..thank you..it has been a long time since this came up,..pls post what you think would help
Smoking...longer is better as long as you don't run into interference from hitting the chassis. We had a super late model , i think it was a port city chassis, has a third link that ran from the top of the quick change to a front mount just behind the transmission.
  • #306
http://www.racetec.cc/shope/
Mainly for drag racers, but tons of info and interactive programs...
Tells me how to get the results, if only I knew what results I wanted!
  • #307
Thanks have had a good read on the 3 link posts.
Seems like a sensible approach before we head to a 4 bar
I notice Ranger Mike you like 20 inch bottom arms were as a GRT have approx approx 15 inch arms
What would the difference in length do in terms of handling.
Would the shorter arm allow the LR to climb under the chassis more and more drive but would it also make for incinsistant handling.
On a 3 link should i mount the coil over in front of axle LR and on top on RR.
Any other pointers like angles etc
THanks for the advice
  • #308
Sierra..
Longer is better because it produces less angle change as one side moves to bump and the other goes into rebound. Shorter is twitchy if you know what I mean. 4 link suspensions use 15 inch lower links. But if the chassis will not permit longer..go with what you can and follow the instant center rule regarding angles.
The coil over mounting was discussed on post # 304..It would help a little with the coil overs mounts in front on the LR and in back on the Rt. rear..Detroit did this in the muscle car era. Not sure it is worth it when you have to crawl under the cat to change springs at the track...keep it simple
per attached ..just for your information
Rear suspension motion rate - MR = A/B
in this case A = 22 inch B = 32 inch
MR = .688Wheel rate = WR
Motion Rate = MR
Spring Rate = SR
WR = (MR)² x SR x (cos)²example if you run 250 # spring and 20 degree angle
WR= (.688)² x 250 x (.94)² or WR = 105 lbs..
  • #309
Here is info on Street Stock class round track car
3100 pounds, full size 76 Impala front and rear
50% rear weight, 60% left side with 58% cross weight
82.5" LFT rear tire, 85" rt. rear tire
A-Arm and coil spring frt. 64.7 inch track, 1.5 degree camber over 3 inch
Lf ft 900# rt ft 1000# springs
rear has panhard bar 61" track width
Lf rear 200# rt rear 175# spring
Ft RC is about right height but we have not offset it to plant more weight on Rt ft to help steer thru the turn
Performance Trends is software..nice packageif we raise the right top ball joint to 20.9" the RC moves 3.0 to the right but is now 3.3 Inch height
If we lower the left top BJ to 2.8 Height the RC is now 3.3 inch to the right and 2.8 inch height and we improve chamber ( less gain)
  • #310
I was just playing with the same software...lol
Seems Iwill have to raise the upper ball joints and inner moumts to get what I want... (Or what I think I want...lol)
How do you feel about upper control arm angles? Better to keep the shafts perpendicular to the centerline of the chassis or match their angle to the pivot angles of the lowers?
  • #311
Rick
When you have parallel upper and lower A-arms you have an Instant Center way out there in space and very little camber build ( gain). Most round track cars are happy with 1.5 degree camber gain per inch travel since the front end lay out won't permit anything less. When you have a lot of upper link angle you have a radical camber build which could work depending upon all other factors. It is all about tire contact patch..
  • #312
if you can do it, try to make the upper and lower links / control arms/ A-arms equal length and parallel. The hot set up is the camber gain we have here..a little over 1.7 degree for 3 inch travel. Make sure you have zeroed out any bump steer and add as much ACKERMAN as possible. If you can do this on your door flapper racing on Saturday night you can run the outside groove and and lap the field pretty much at will. Its all about tires!
  • #313
I better go back to school and learn how to communicate...lol
I meant from a top view... lower arm pivots are angled ahead (front pivot point closer to the chassis center than the rear) but the upper arm pivots are almost perpendicular to the frame centerline... Is this to change caster as the front dives?
What about antidive?
  • #314
Personally , I am not into ANTI anything on a race car. Adding in Anti Dive, anti squat, droop limiters etc.. to a poor performing race car to keep it from pushing is at best a Band-Aid if you think about it ...you are trying to treat the problem not the cause. t am a big believer in using a cars suspension to deal with weight transfer. I don't even like roll steer but in some classes, its all you can do to make the most with a bad situation. We all know why unsprung weight is so evil..you can not control it. So, with that line of thought, sprung weight is " good" because we can control it..right? So how best to control the weight transfer? Springs and shocks and ARB (sway bar).
Leaning wishbones back to arrive at a antidive characteristics was common in formula 1 a while back. Indy cars several teams experimented with hydraulic devices to keep the attitude (rake) of the car constant to get a stable aero platform (was something of a antidive /anti squat system).
With modern (shock) damping technologies you should be able to get on top of most of these problems and not get lost with introducing new variables to combat short comings of your particular car. Why would you introduce a setup that will run out of travel and go into spring/coil bind or use pump stops to handle any weight transfer.
Anti-dive is a suspension parameter that affects the amount of suspension deflection when the brakes are applied. When a car is decelerating due to braking there is a load transfer off the rear wheels and onto the front wheels proportional to the center of gravity height, the deceleration rate and inversely proportional to the wheelbase. If there is no anti-dive present, the vehicle suspension will deflect purely as a function of the wheel rate. This means only the spring rate is controlling this motion. As anti-dive is added, a portion of the load transfer is resisted by the suspension arms. The spring and the suspension arms are sharing the load in some proportion. If a point is reached called 100-percent anti-dive, all of the load transfer is resisted by the suspension arms and none is carried through the springs. When this happens there is no suspension deflection due to braking and no visible brake dive. There is still load transfer onto the wheels, but the chassis does not pitch nose down.
The method to achieve anti-dive is controlled by the upper and lower control-arm pivot points on the chassis. In all suspensions there is a factor called the side view swing arm. This is a theoretical point of intersection of the arm planes projected into the fore-aft vertical plane through the wheel center. If this point is behind the wheel and above the ground, it will produce anti-dive. It will also provide anti-dive if it is below ground and ahead of the wheel. The other possible locations for this instant center are ahead and above ground as well as behind and below the ground. With these locations we have pro-dive. This means as the brakes are applied the suspension travels more than it would without any anti- features. The magnitude of the anti-feature, either pro or anti, is a function of how far the instant center is away from the ground. If it is on the ground, there is zero-percent anti-feature.
On passenger cars, anti-dive is added to make the pitch motions under braking more tolerable for the occupants because of the typical soft spring rates. The anti-dive is made the same for both sides of the car because most people brake in a straight line, and there is no directional preference on the street or in road racing for that matter. In circle-track racing it is common for racers to take any parameter to and beyond its limit. In the evolution of the circle-track chassis, they have come to a solution that provides pro-dive on the left-front and anti-dive on the right-front suspension. The reasons for this are varied. For one thing, as the brakes are applied the car will deflect more on the left front than on the right. This will give a feeling of the front leading into the corner and not rolling out right away. This combination also provides for more of the load transfer to the front to be carried by the right-front wheel than the left front. The total transfer is the same; just the distribution is affected by the anti-feature in the geometry. More load transfer to the left front on corner entry is like taking wedge out of the car with the brakes. Why? When we turn left with a positive caster, the lft ft tire rises and is the result of jacking weight into that corner and taking wedge out of the car. The more positive caster used on the lft ft, the greater the steering axis angle change, the greater the loss of cross weight as we turn left.
Anti-dive has an effect when there is a torque trying to rotate the spindle relative to the chassis. The typical case for this is under braking, but there is another case that can alter the loads and deflections of the wheels. This is the drag component of cornering load. When the wheels are turned and the tires are cornering hard there is a longitudinal load relative to the chassis centerline trying to rotate the spindle. To visualize this, think of the wheel turned 90 degrees!
Just like anti-dive in the front suspension, there can be anti-lift in the rear suspension that reduces rebound travel under braking. There is also anti-squat in the rear suspension under acceleration for rear-wheel-drive cars.
next up Caster...and effect on handling..need beer run
  • #315
Ranger Mike said:
Flashpuppy..
welcome..
i assume you have some kind of limited slip differential in the quick change..right?
coming up..rear end mounting , trailing arms etc..
Yessir. Winter's is whipping together a nice little LSD unit for me.
I am having a bit of diffuculty figuring out a functional rear suspension due to my extremely short wheelbase. If my math figures out correctly, my four-link bars (if I was running them) would need to be mounted about in my abdominal region. I know I'm running into all sorts of problems because of the low ride height/tall tire combination and extremely light weight. I was thinking that a torque link setup would be nice as I could run the third link into the trans tunnel and give myself the type of length needed.
I am looking forward to seeing what you have to say about rear-end mounting.
  • #316
wow... the RC sure move around a lot when the car dives and rolls...
It seems to want go to the left side... is this bad? Compromises as usual...
My suspension actually measures very close to the demo street stock...
So, since I can only move upper mounts, should the roll center be calculate with the suspension at rest, or while down and rolled?
Starting to think that drawing the lines on the floor might be less time consuming...lol
  • #317
flash puppy you may have a very twitchy car when your done...that said..try to keep the links as long as possible..note IC locations in previous posts..maybe think about a leaf spring like to old T buckets used.. keep the coil over angles between 15 and 20 degrees if you run those ..how about torsion bar rear suspension?
good for low profile mounting if you have room...
  • #318
rick..excellent point..you nailed it..In my haste to post a reply, see post 309, i did not do a good job following thru..I assumed the post i did on the RC location was for a car that you could tweak to keep the RC close to its static position..the migrating RC has always been a problem..but..in my opinion. if you can keep it some where to the right side and reasonably low during first inch or two of travel..you will put enuff load on the rt ft tire to turn the car...
...the set up you have, if it is like the attached, is pretty good for a stock class racer..about as good as you can get on the front end restrictions the rules dictate..
RC ends up about 2.1 from ground and 5 inch offset to right in 2.8 inch dive...not too bad
you are far more better off with this set up than the guy who starts out with it centered and high and it moves to the left when in dive
If ignorance is bliss, why are so many people unhappy..same this racers
  • #319
caster - inclination of the steering axis from the vertical in the longitudinal plane ( side view). Positive caster means the top ball joint is trailing the bottom ball joint..i.e. top BJ is further to the rear of the car than the bottom BJ. Think of a bicycle front fork or that broke down beat up shopping cart I always seem to get at Wal-Mart..The effect is that the wheel self centers with positive caster. Negative caster is just the opposite. Caster does several things. It provides positive feed back to the drive, self centers the car, changes the amount of weight transferred during cornering, builds the drivers biceps. When car with Positive caster turns left, it lifts the left ft. tire, dips the rt. ft tire. The steering axis multiplies the effect of Positive caster and the amount of lift / droop. The greater the inclination the more Positive caster will change the cornering height of the car as the wheel is steered. You can plot this on a curve from 0 to 20 degree and see the lift if you have a set of turn plates. When the car is turning left, the result is jacking weight into the left front tire, and right rear tire, taking wedge ( cross weight) off the right ft tire and left rear tire. The more Positive caster the more loss of cross weight. Anti dive discussed above adds to this effect.
Caster split- In round track racing we run a caster split. The right side has more caster than the left side. Typical setting is +1 Left side caster, + 3 right side caster. If set up correctly, the car will steer real easy down the straight and darn near turn by itself through the turn. if you run power steering then you can add another degree on the right side Positive caster. Run too much caster and your driver will develop muscles quick. Most drivers are happy with 2 to 3 degree split, any more than that, things get tuff to turn.
  • #320
Just bought an old street stock GM metric chassis race car from across the state. It has tubular uppers front control arms that are mounted to custom mounts. it also has the tall Impala spindles. The local 3/8 mile dirt oval requires stock upper/lower control arms with stock type front shocks mounted through the center of the springs. Hidden weight jacks are allowed as are custom upper arm inner mount locations.
I picked up some junkyard upper arms and am trying to figure out the best place to mount them. I found that if I swap the right/left side stock control arms, it looks like I can then get the pivot axis to be parallel to the lower control arms.
My goal is to have as low as possible upper control arm pivot axis that is parallel to the lower control arm pivot axis and then weld the mounts on positioned to give me the proper inital camber/caster with no anti/pro dive.
Has anyone heard of doing this right/left control arm swap to a metric chassis where rules permit?
  • #321
Mike I have been following this thread with dedicated interest for awhile and I am now hoping for a little advice. I am the process of building a road course GT car from a 2005 superspeedway cup chassis. The car will be using 13" wide GT slicks on 16x12 rims. I am wondering at what height a good RC design should be located on the front along with a good scrub radius (I have Perf Trends CT Analyzer). The chassis will be set pretty low(4" clear at static RH and 2"- at dynamic) with a low static V8 engine location for a static CG height of around 16" or so if you consider the cam tunnel the CG. I am using the as-built lower pivot locations with fabbed lower A-arms that are extended horizinstally 2.5" from standard cup stuff and going full coil over. I have plenty of options as to how high/low to locate the dynamic RC as I am re-fabricating at this time. I am wondering where you think setting the dynamic RC would be best applicable to get the best mid corner speed. The rear is truck arm with a panhard bar. Wanted to go watts link but just could not get it done this year maybe next year.
I also read the post above about track width front to rear. At what point does a wider front track width become an issue. I will be at 80" front and can set the rear at whatever I would like, to again maximize mid corner speed. How much offset is too much or where does the difference become too much of an issue.
Thanks
Dan
  • #322
Dano..welcome..you have the most important tool in your tool box...the chassis software..good show...I recommend you use it to mount upper links as parallel to the lowers as possible and get best camber curve. Front RC will be lower than the rear and try to go as low as you can and keep it centered through full dive. No offset since you are going left and right on the course.
I did some research on Track width.. will work on scrub radius latter but think about the following.
See post # 255 above regarding TRACK WIDTH (TW)
The Ford GT had 57" front and 56" rear TW and won Le Mans..Henry Ford spent millions on this so why reinvent the wheel..use the resources the big auto makers figured out and move on to other things you can improve on..
Here is a cut from a SAE paper that at least is on of its own.
"When selecting the track width, the front and rear track widths do not necessarily have to be the same. For example, track width is typically wider in the front for a rear wheel drive race car. This design concept is used to increase rear traction during corner exit by reducing the amount of body roll resisted by the rear tires relative to the front tires [4]. Based on the corner speeds and horsepower to weight ratio of FSAE cars, this concept should be considered by the designer". Take a car with 50/50 weight distribution, equal roll stiffness each end, same tires etc in a steady state corner (no wonder vehicle dynamics is confusing, we regard continual acceleration as steady state)
As the rear track is decreased, the load difference between inside and outside rear tires is increased for the same couple. The maximum lateral force capacity of a tire pair is achieved when the tires are equally loaded. So, when the rear track is decreased, the lateral force capacity of the rear tire pair is decreased, and the result will be more Overseer.
The track width is normally measured to the centerline of the tire. If the front tires are narrower than the rears, but at the same time you are exploiting the maximum width available - then the front track will be wider than the rear (but not necessarily the overall width of the front).
The more track width you can have the better you can take corners for a given tire size because the load transfer from the inside to the outside is less, so the tires are sharing the work better.
Even with the likelihood that track width is driven by the regulations, a wider front track can be useful. As a car brakes and enters a corner (assuming trail braking by the driver) - then the load is transferred from the inside rear to the outside front (diagonally) - a wider front track will help the car on corner entry.Going through my database of front/rear track differences in sports cars a new fact has come to the fore. When I compared F/R track in cars released in the last 4 years the ratio has changed from that previously noted. It is now 3:1 wider at the front.
Wider at front:
Noble m15 89mm wider at front
Ferrari F430 53mm wider at the front
Lamb Gallardo 30mm wider at the front
Porsche Cayman 42mm wider at the rear
Bottom line - wider front track ( compared to equal ft to rear track width) means the body will roll LESS because you have a longer distance between wheel center line to take the same amount of load transfer. Less roll means more " stability ", less push ( under steer). For road course set up keep front TW at least 1 inch wider or as a minimum, equal to rear TW
  • #323
Mike thank you for the reply, in regards to the Dyn. RC should I go below the ground level or keep it above? and if so how much below/above would be a reasonable location? If upper/lower links are close to parrellel wouldn't that put the ICs way outside of the track width? Is this a good thing?
As for the track width offset (65"F - 63.5"R) I was thinking of using 1.5" difference F-R. Do you think this is too much offset? Or would this have any negative effects on handling and if so what?
Thanks again
Dan
  • #324
One other aspect of a low RC is you have minimal track width change during body roll and thus tire scrub is minimized during cornering. Try to keep the RC at least .5" above ground.
I think the 1.5 inch track width is right on...
Regarding the IC and scrub radius...i am working on this post ...but if it falls between 3.5 and 6 inch you should be ok..more on this later
  • #325
If we draw a line through the top ball joint , bottom ball joint to the ground we have the Kingpin Inclination Angle, also known as Steering Axis Inclination. Typically this angle is between 5 and 10 degrees and 7 to 9 degrees being best compromise for Stock cars, big sedans running 12:1 ( most common) 10:1 or the very quick 8:1 which both require power steering. 6 to 8 degrees for open wheel road course cars running 16:1 steering ( two turns lock to lock).
The scrub radius is the distance in front view between the Steering Axis Inclination and the center of the contact patch where both would theoretically touch the road.
The point at which the steering axis line contacts the ground is the fulcrum pivot point on which the tire turns. The location of this point within the contact patch has a great effect on steering effort, feel, and stability. If you have not already guessed, the easiest way to change scrub is by changing your offset with either new wheels, or hub centric wheel spacers. Scrub radius should be kept at a minimum but not Zero. Zero scrub radius (center point steering) means the car will react too quickly and steering is " darty". The car will steer very easily and give no feedback to the driver. It is like driving your car on ice. No feel.
If the scrub is zero, the scrubbing action of the contact patch is equal on either side of the pivot point causing the tire to act like a car with a locked differential, inducing a condition called 'squirm'. In a straight line the tire tends to be stable and tracks well. As you turn though, the portion of the contact patch on the outside of the pivot point moves faster than the portion on the inside of the contact patch. Since the scrubbing area is equal on each side of the pivot point, yet the forces are different, the tire tends to fight itself and it becomes 'grabby' causing tire wear to increase and the steering to become unstable.
Any bump or cornering force that is applied to the tire can exert a twisting force on the steering that is proportional to the length of the scrub radius. Increasing SAI helps to self center the steering. But if too much SAI causes lateral scrub of the tires in the turn and really heats them up. Lot of wear.
When in a left turn, Scrub lengthens the right side wheel base and tends to loosen the car. When you counter steer, it shortens the wheelbase and adds understeer. This is a driver friendly situation as it has a very stabilizing effect to the cars handling in driver feed back. The driver needs feedback in a turn because it tells him how heavy the tires are loading and when they are on the edge of traction.
Positive and negative scrub radii have benefits in different types of suspension. A MacPherson strut assembly typically performs well with a lot of SAI and caster, a system negative scrub works well in. Because both SAI and caster increase the amount of camber on the outside wheel when steering, the fulcrum pivot point is at a point that has more leverage, requiring less steering effort. Negative scrub also helps reduce torque steer in front wheel drive cars. Positive scrub radius works well with suspensions that use dual control arms that use less caster and SAI to optimize geometry.
As with anything else, a little of a good thing is great, but lot of a good thing is not necessarily better. When you have excessive scrub, whether it be positive or negative, steering effort increases and road 'feel' increases, as the steering is more susceptible to road shock. Additionally, if you plan on doing some homework on, and modifying your scrub radius, you must take into account the amount of sidewall flex your tire will encounter under hard cornering. When the sidewall flexes, the contact patch moves in relation to the SAI and can make a slightly negative scrub radius become zero.
Our open wheel formula car runs about 2.5 inch scrub radius. Late model stock cars will run 10 to 12 inch wide tires and 4.5 to 5 inch scrub. The left front will have 1 to 1.5 inch more scrub due to positive camber used on that side. As far as I can recall scrub should be between 3.625 and 6 inches with right front having 5 inch.. being " ideal' for most fast late model cars.
Mechanical Trail - SEE POST # 319 ABOVE - Also know as or caster offset , is the horizontal distance from where the steering axis inclination intersects the ground to where the front wheel touches the ground. The measurement is considered positive if the front wheel ground contact point is behind (towards the rear of the car) the steering axis intersection with the ground. More trail will give the feel of " returnability " of the steering. Less will give the feel of the steering being " floaty". .
  • #326
Mike thank you again for all of the information. I will try to stick with around the 5" scrub radius at both sides of the car. I will be measuring and mocking this weekend to get the front settled. I will let you know if I need anymore advice. Again thank you for your time, it is greatly appreciated.
Thanks
Dan
  • #327
we had some discussion about Anti Squat..I found this when I was digging through my note..food for thought
  • #328
I had a question on changing rear end mount brackets..here is one case..it is an example of fabricated mounting bracket for Panhard or J bar..make them beefy and lot if support..car manufacturers spend lots of time and money to design the proper mounts and I don't like to deviate from them unless it is for max performance and can be justified..but you can do it..
  • #329
measuring centerline
Do you measure the centerline of your car at
1 between the Aframe mounts.
2 between the tire contact patches.
3 between the moment center where the car rolls which would depend on left side weight .
  • #330
smokin..which ever method you use..you have to use it every time. The tire patch method is ok but if you ever go to offset wheels or spacers..you have all readings off form that point. The recommended method is from A-arm mounts..I go off the lower A-arm mounts, drop a plumb line from each to the poster board, find the center line and project it back to the rear of the car with a long piece of aluminum and find my center line from the frame rails at the rear. The drive line will be close to center but I found that components are usually offset a bit. I use a 3 foot carpenters square to project the center line up to the car frame at several points and PAINT a line on the frame, chassis etc...so I don't have to repeat this drill.
  • · Replies 20 ·
9K
  • · Replies 49 ·
