Please help transistor amplifier
The discussion revolves around designing a common emitter (CE) transistor amplifier with a specific voltage gain. Participants explore the calculations and component values necessary to achieve desired gains, including the relationships between resistors and transistor parameters. The conversation includes both theoretical and practical aspects of amplifier design.
  • Homework-related
  • One participant seeks guidance on how to achieve a desired voltage gain of 50 for a CE transistor amplifier, providing specific input parameters.
  • Another participant suggests that to achieve a gain of 2, the collector resistor (rc) should be 2K and the emitter resistor (re) approximately 1K, while introducing the concept of r'e.
  • There is a discussion about the input impedance of the transistor and how it complicates achieving the desired input impedance of 50K.
  • Some participants propose using two stages of amplification to reach a higher overall gain, with suggested configurations for each stage.
  • Participants discuss the calculations involved in determining the gain based on the load resistor (rl) and collector resistor (rc), emphasizing the need to consider parallel resistances.
  • There is a clarification on how to calculate r'e based on the bias current and thermal voltage, with some participants expressing uncertainty about the derivation.
  • Concerns are raised about the precision of gain in transistor amplifiers due to variations in components and temperature effects.
Participants express varying levels of understanding and agreement on the calculations and design approaches. There is no consensus on a single method to achieve the desired gain, and multiple competing views on the design process remain evident throughout the discussion.
Participants mention the importance of approximations in calculations, the impact of temperature on transistor behavior, and the challenges of achieving precise gains. The discussion also highlights the complexity of designing amplifiers with specific input and output impedances.
This discussion may be useful for electronics students, hobbyists, or professionals interested in amplifier design, particularly those looking to understand the nuances of transistor amplifier calculations and configurations.
michael1978
can somebody teach mm
how to find desired voltage gain of ce a transistor amplifier
which is formula, i know the formula is rc:rl/re
but i want for example a voltage gain of 50
for example
input desired data:
desired voltage gain 2.0 which i want to know
f_min = 10 HZ
z_in = 50 K
Z_OUT = 2k
power suppply 12V
now how is the formula to find
r1 r2 i know to find
but rc and re i don't know to find, that is my problem
for example
input desired data:
f_min = 10 HZ
z_in = 50 K
Z_OUT = 2k
power suppply 12V
You want output to be 2K, your rc has to be 2K. You want voltage gain of 2, so you want your re≈1K. Gain=rc/(re+r'e) where r'e= 1/gm≈Vt/Ic. Vt≈25mV at 25deg C. For Ie=1mA, r'e≈25Ω. So if you use 1mA bias current, re=1K is close enough.
If you choose a NPN with β>100, input impedance of the transistor is βXre≈100K, this is going to be a little tricky getting input impedance of 50K as the input impedance of the transistor is as low as 100K or higher if β is larger.
What is r1 and r2? is this a voltage divider to bias the base of the BJT? If so, you want Zin=50K, then you want r1//r2=100K so you get about 50K when parallel with the input impedance of the transistor. But this is not reliable.
You need to relax some requirement, if you can accept output impedance of say 20K, then re=10K and your input impedance of the transistor can by up to 1MΩ. Then you can ignore the input impedance of the transistor and make r1//r2= 50K.
For fmin, C=1/(2πRf) where R=50k input impedance, f=10Hz.
thnx for reply very good
but can i ask you one question if you can explain in similary way
what for example, i want to desigin a amplifier with gain of 50, how can i design?
for example me i design a amplifier in the end i get other gain, and i want a gain of 50
can you teach me how to do it, to get desired voltage
For a high gain (e.g., 50) there are advantages in using two stages, each using one transistor. The first stage could have a voltage gain of x10, and the second a gain of x5.
But whatever voltage gain you need, for each stage you still use the equations that yungman provided, viz.,
Gain AV=rc/(re+r'e) where r'e= 1/gm≈Vt/Ic. Vt≈25mV at 25deg C. For Ie=1mA, r'e≈25Ω.
yes i know, can you show the first stage gain for example to be x10, which steps i have to take? which FORMULA? i know the gain is rcllrl/re , but i want for example x10 OF x5 ANY DESIRED VOLTAGE GAIN CAN YOU SHOW ME EXAMPLE PLEASE FOR DESIRED FIRST VOLTAGE GAIN
oh sorry i forget, if is rl load connected with rc, how you calculate can you teach like in first example please, show me example please thank you
If you connect rl to rc, then the gain will change like you said = (rl//rc)/re. The calculation I show was direct answer to your original request Zout=2K which is rc. Gain without load rl, equal 2.
For example, say if you keep Zout=2K, rc has to stay at 2K. Say if rl=2K, then rc//rl=1K. To get a gain of about 2, re=475Ω ( as for Ie=1mA, r'e=25Ω). But then, you have to worry about Zin as Zin=β(re+r'e)≈50K! That is not a reliable value.
sorry and have you get re = 475OHM? LIKE THIS 1000/2? is 500OHM
Remember gain=(rc//rl)/(re+r'e)
As I assume Ie=1mA, r'e=25Ω. rc//rl=1K. For gain of 2, re+r'e=500Ω so re=475Ω.
ah so r'e=25Ω 1ma and re 475 so in total 500, you mean like this? but how you get r'e=25Ω?
what i have to do to get r'e=25Ω, like this 25m:ie 1ma = 25ohm
r'e=1/gm=Vt/Ic. Just trust me with Vt=25mV at 25 deg C. That gets into semi conductor physics. I am not expert in it and the approximation I gave is quite good already. That's all you need to know unless you really want to dig into it.
Remember this formula r'e=25mV/Ic. If you use 2mA, r'e become 12.5Ω. If you use 0.5mA, r'e become 50Ω. You get the drift?
Don't try to get precision gain using transistor, it drift a lot with temperature and different device even of the same name.( even using 2 different 2N2222 give you slightly different gain). That's the reason, using approximation is very good already. You want precision, you need closed loop feedback like an op-amp.
is that 25mv/ie of 25mv/ic, i learn till now r'e=25mV/Ie not ic
I believe it is supposed to be Ic, but then again, it is an approximation. Ie≈Ic in all respect if β>100. There are so many variables in these formulas you just use approx number. Here is the page explain in a lot more detail, actually they use Vt=26mV, it's close enough!
http://en.wikipedia.org/wiki/Bipolar_junction_transistor
Unless you really get into semi conductor physics, 25mV is good enough. I pretty much designing IC( actually all transistor circuits inside) using this approximation those days and it worked.
One thing I did not mention, you don't want to get gain of 50 out of one stage. Remember I show you how to calculate the Zin and Zout? You want Zout=2K, for gain of 50, the re+r'e=40Ω, that is low, then your Zin=βX(re+r'e)≈4000Ω. You cannot get Zin = 50K! Even if you can get the impedance you want, there are more limiting factor that you have not deal with, one namely Miller Effect that the circuit slow down as the gain goes up. These are a lot more important in real life than the Vt. If you want gain of 50, divide the gain into 2 separate stages of about 7 each.
thanx for help, is enough for begin
do you know any good book about electronics transistor
because now i am reading electronics principles by malvino
That's the best book...bar none! Everything I posted is in the Malvino! I gone very far as an engineer using nothing more than Malvino. Yes, I got into BJT IC design with just the knowledge of Malvino, it's that good! Of cause I learn a whole lot more since then, but it's good enough to get you started as an engineer.
You better read the part about Vt again, it's all there.
so its good book just to read good and to understand thnx for advice
can i ask you something which symbols is this || for exaple rc||rl
is not rc divide rl, i thought || is divide / but is not
can you tell how you calculate with this symbol ||
thnx
If you have a resistors connect in parallel you use this two parallel lines "||" to express it
R1||R2 = (R1*R2)/(R1+R2)
I use // as parallel. And Jony130 is correct.
§thank you ver much
You're welcome, keep digging into Malvino, it's worth your time. I hold this book is such high regard I did try to order a newer edition last year, but I ordered the experimental manual by mistake. I lost my original book long long time ago...since the early 80s. I want to keep a copy in my library collection.
Another part Malvino is very good is the op-amp. I still use what I learn from the book. Of cause you need more on Bode Plot stability design, but this really give you a strong start. I designed many closed loop feedback system, I use the Bode Plot starting from what I learn from Malvino.
thanx man
may i ask you something
FIRST
is this formula OK
for example rc=(3.600X10000)/(3600+10000)=2650
desired voltage 0.5, 2650/0.5=5300 so re=5300
voltage gain is 2650/5300=0.5
is this correct formula? if is this is correct formula why my simulator is 43mV not 50mv
where is wrong my formula of my simulator? can you exaplian me please thanx
SECOND how if you connect one re in serie with r'e, how decrase voltage gain, can you explain in similary ways please
Why you built a amplifier with gain smaller then one?
i am trying to learn like in book, transistor ce class a, and i do experments with software, but like you see my result are not correct, i do somewhere mistake
michael1978 said:
thanx man
jjjjj
FIRST
is this formula OK
Show as a diagram and all components values.
And tell as how long you have been learn electronics?
  • · Replies 20 ·
  • · Replies 41 ·
9K
