| Thread Closed |
[SOLVED] Half Life Help |
Share Thread |
| Dec19-07, 03:21 PM | #1 |
1. The problem statement, all variables and given/known data
The activity of a radioisotope is 3000 counts per minute at one time and 2736 counts per minute 48 hours later. What is the half-life of th radioisotope? This is where I'm completely lost. |
| Dec19-07, 04:28 PM | #2 |
See here for some information:
http://hyperphysics.phy-astr.gsu.edu...alfli2.html#c3 http://hyperphysics.phy-astr.gsu.edu...alfli2.html#c2 You first need to figure out the decay constant (represented by [tex]\lambda[/tex]), which you can do by using the decay equation. Once you have that, you can find the half-life*. The equations you need are in the link. Give it a try and see what you come up with. *Or you could just substitute the expression for lambda (which relates to the half-life) into the decay equation and solve for the half-life all in one go. Same thing. |
| Dec19-07, 04:55 PM | #3 |
[tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex]
[tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex] Take 3000 counts as [tex]A_{0}[/tex] and 2736 counts as [tex]A_{t}[/tex] Also, do you know how the half-life equation is derived? And what connects these 2 equations? *don't forget to convert your units. |
| Dec19-07, 05:48 PM | #4 |
ok so [tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex] is what I'm going to use to calculate k
and then i use [tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex] to calculate for [tex]t_{\frac {1}{2}}[/tex] |
| Dec19-07, 06:09 PM | #5 |
Did you get an answer?
| Dec19-07, 07:04 PM | #6 |
yeah I got 21661 mins which then I converted to hours and that is 361 hours.
| Dec19-07, 07:07 PM | #7 |
| Thread Closed |
Similar discussions for: [SOLVED] Half Life Help
| Thread | Forum | Replies | ||
| [SOLVED] Decay equations: Given A0 & At, find half-life, lambda and N0 | Introductory Physics Homework | 14 | ||
| The half-life of carbon-14 is 5568 years. | Biology, Chemistry & Other Homework | 0 | ||
| Half Life and Half Life 2- The computer games | General Discussion | 25 | ||
| [yahoo] No half measures with Half-Life 2 | Computing & Technology | 0 | ||
| [SOLVED] Half Life | General Physics | 1 | ||
