| New Reply |
prove e=mc^2 |
Share Thread | Thread Tools |
| Sep6-12, 01:29 PM | #1 |
prove e=mc^2
if possible could you tag some good video lectures may be feymann or any other good source..thanks...!!
| Sep6-12, 02:25 PM | #2 |
Prove? This is like asking someone to prove Quantum Mechanics. Mathematically, there are a ridiculous number of consistent theories, so all we can do is fail to disprove it.
| Sep6-12, 03:22 PM | #3 |
Recognitions:
http://en.wikipedia.org/wiki/Special_relativity
http://en.wikipedia.org/wiki/Mass%E2...gy_equivalence Try either of the above. |
| Sep6-12, 04:28 PM | #4 |
prove e=mc^2
are there any good feymann lectures on special theory of relativity or quantum mechanics...???
thanks!! |
| Sep7-12, 03:36 AM | #6 |
In special relativity, time is just another dimension, just like spatial distance. The numerical value of the speed of light is a proportionality factor between time and length units. This identification causes a series of other identifications.
Speed becomes an angle between the time directions between two moving reference frames. This also nicely explains Lorentz transformations and relativistic speed composition. Mass, momentum and energy are also identified. The proportionality factors between the standard units of these parameters are: momentum is mass times c and energy is mass times c squared. That's all. Electric and magnetic potentials also undergo an unification into electromagnetic potential. This is the basic idea of the special relativity. We live in a 4D space. Our common 3D physical properties turn out to be spatial or time-like components of 4-dimensional properties. Time and space are the same, but our standard unit system (say SI system) has different units for them. When we want to convert from time to space, we need to multiply the numerical value of the property by some proportionality factor, which is always some power of c, depending on the dimesionality of our property. |
| Sep7-12, 02:17 PM | #7 |
because it what we perceive from different reference frames due to account of special relativity and we can't say that actually a some lump let say of m mass is vanishing(or more precisely should i say converting to energy)... doesn't really happen whatever we measure is due to special relativity effect!! |
| Sep7-12, 03:18 PM | #8 |
Recognitions:
| Sep7-12, 04:50 PM | #9 |
| Sep8-12, 04:49 AM | #10 |
OP was refering to total mass and total energy as I understand. These quantities never change for an isolated system and are always proportional to each other with a factor c^2. |
| Sep8-12, 09:19 AM | #11 |
It's also not true that total mass is separately conserved. Mass isn't even additive. E.g., in Einstein's 1905 paper, the body that emitted the two light rays in opposite direction lost an amount of mass L/c2. Each light ray has zero mass. The sum of the masses has been reduced by L/c2. However, if you put the whole system, in its final state, inside a box, its inertia is the same as that of the original system, and unequal to the sum of the three masses. What's conserved isn't mass or energy separately but mass-energy. |
| Sep8-12, 09:37 AM | #12 |
E=mc^2 is most easily proven through an action principle imo. Check out Landau and Lifshitz second book, classical field theory (only the first few chapters)
| Sep8-12, 10:39 AM | #13 |
There are different physical quantities calles "mass" and "energy" and they are not the same despite they have similar names. |
| Sep8-12, 10:51 AM | #14 |
haael, it seems you are not aware of the convention used by almost all physicists nowadays that the term "mass" on its own is taken to mean "rest mass". The version of mass you are talking about is nowadays called "energy" (divided by c2).
| Sep8-12, 11:01 AM | #15 |
It releases binding energy of a nucleus. To me so far, E=mc2 is a conversion factor. Conversion of Kg into Joules. |
| Sep8-12, 11:12 AM | #16 |
This jargon is very misleading, by the way. Many non-specialists in the world have hard time understanding what all this actually means. |
| Sep8-12, 11:38 AM | #17 |
| New Reply |
| Tags |
| quantum mechanics, special relativity |
| Thread Tools | |
Similar Threads for: prove e=mc^2
| Thread | Forum | Replies | ||
| Prove (100-100)/(100-100)=2 | General Math | 18 | ||
| Prove that a rational root of a monic polynomial is an integer. Use this to prove... | Calculus & Beyond Homework | 1 | ||
| Prove that if C > 1, lim .... | Calculus & Beyond Homework | 0 | ||
| How to prove this? | Classical Physics | 0 | ||
| How to prove that? | Calculus & Beyond Homework | 2 | ||
