Wave Intensity: A^2(z,t) at (15 cm, .5s)
  • Thread starter Thread starter UrbanXrisis
    Intensity Wave
The wave intensity is defined as the squared wave amplitude, represented mathematically as I(z,t) = A^2(z,t). In this discussion, the wave amplitude A(z,t) is given by the equation A(z,t) = a cos [2 π (r/λ - t/T)], with a wavelength (λ) of 10 cm, a period (T) of 1/10 s, and an amplitude (a) of 1 mm. To find the instantaneous intensity at r = 15 cm and t = 0.5 s, the solution is A^2(z,t) = (0.1 cos [2 π (15/10 - 0.5/0.1)])^2. For the average intensity over time at that location, the integral approach is correct, requiring division by the period T after integrating from 0 to T.
  • Understanding of wave mechanics and wave intensity
  • Familiarity with trigonometric functions and their applications in physics
  • Knowledge of integration techniques in calculus
  • Basic concepts of wavelength and wave period
  • Study the derivation of wave intensity formulas in physics
  • Learn about the properties of cosine functions in wave equations
  • Explore integration techniques for periodic functions
  • Investigate the relationship between amplitude, wavelength, and wave speed
Students and professionals in physics, particularly those focusing on wave mechanics, as well as educators seeking to explain wave intensity and its calculations.
UrbanXrisis
the wave intensity is defined as the squared wave amplitude.
[tex]I(z,t)=A^2 (z,t)[/tex]
[tex]A(z,t)=a cos [2 \pi (\frac{r}{\lambda}-\frac{t}{T})][/tex]
the wavelength is 10cm
period is 1/10s
a=1mm
1. what is the instantaneous intensity at r=15cm and t=.5s?
is the solution:
[tex]A^2(z,t)=(.1 cos [2 \pi (\frac{15}{10}-\frac{.5}{.1})])^2[/tex]
2. what is the average intensity averaged over a long time at that location?
[tex]\int A^2(15,t)=\int_{0}^{\inf} (.1 cos [2 \pi (\frac{15}{10}-\frac{t}{.1})])^2 dt[/tex]
is that how I would solve #2?
Integrating like that would give you a total sum. You need to divide it by the time to get the 'average'. A trick would be to integrate from 0 to any T (period of the wave) and divide it by T.
