What is the Lagrangian and equation of motion for a sliding rope on a table?
  • Thread starter Thread starter stunner5000pt
    Mechanics
The discussion revolves around determining the Lagrangian and equations of motion for a uniform rope sliding off a table, with a focus on applying Lagrangian mechanics. The scenario involves a rope of length l and mass m, with one end hanging over the edge of a table after being nudged with an initial speed Vo.
  • Participants discuss the formulation of the Lagrangian, the relationship between variables r and y, and the dynamics of the rope's motion. Questions arise about the definitions and roles of r and y in the context of the problem.
Some participants are providing guidance on how to approach the problem, including suggestions to divide the Lagrangian into parts corresponding to different sections of the rope. Multiple interpretations of the variables and their relationships are being explored, but there is no explicit consensus on the formulation yet.
There is a note of missing clarity regarding the definition of r and its relation to the motion of the rope, which is central to the discussion. The problem is framed within the constraints of using Lagrangian mechanics specifically.
stunner5000pt
But *must* be done using algrangian mechanics
(because its so much fun taht way)
A uniform rope of length l and mass m lies on a horizontal table with one side just barely over the edge. The rope is given a nudge, taht is an initial speed Vo and begins to slide off
Assuming that friction is negligible, determine the Lagrangina of this system and the resulting equation of motion
[tex]T = \frac{1}{2} m \dot{r}^2[/tex]
the force of gravity acts on the mass hanging off the edge only so
[tex]F = \frac{my}{L}g = - \nabla V(y)[/tex]
[tex]V(y) = \frac{mgy^2}{2L}[/tex]
can r be found in terms of y, though?
any help is greatly appreciated!
You haven't made clear what r is. If it's the distance traveled by some point on the string, as it must be (up to a constant) for your formula to be correct, then the relation to y should be obvious.
r would be the direction vector for any point on the string
so fr example the right end of the rope at t=0 is y=0
then r'(0) = v0
after time t the end opf hte rope has traveled v0 + gt
so r(t) = v0 t + gt^2 / 2?
r'(t) = v0 + gt
is that correct?
Divide lagrangian in two parts such that L=Lh+Lt where Lh is lagrangian of piece of rope that is hanging over the edge and Lt is part of rope lying on the table. It it quite simple. If you have any trouble with that, just yell.
  • · Replies 0 ·
