Troubleshooting a Faulty 3 Phase Motor
The discussion centers on troubleshooting a faulty 3-phase induction motor that overheats even under no load. The issue was identified as a fault in one of the rotor bars, confirmed by a local rewind shop. The overheating is attributed to shorted turns in the rotor, similar to a transformer experiencing a short circuit in the secondary winding. To test for this fault, users should check for continuity between the rotor cage and the iron stampings, ensuring there is no current path.
  • Understanding of 3-phase induction motor operation
  • Knowledge of rotor and stator components
  • Familiarity with electrical resistance testing
  • Basic principles of electromagnetic induction
  • Learn how to perform continuity tests on motor windings
  • Research methods for diagnosing rotor bar faults
  • Study the principles of electromagnetic induction in motors
  • Explore thermal management techniques for electric motors
Electrical engineers, motor technicians, and anyone involved in the maintenance or troubleshooting of 3-phase induction motors.
wolram
Dearly Missed
i had a problem with a 3 phase motor last week that
had me stumped, it would rapidly overheat even under
no load, resistance readings of the windings cheked
out ok as did short circuit tests, a report from
the local rewind shop said that one of the BARS on
the rotor was found to be the fault, can someone
please explain what they mean, and how to test for
this fault?
An 3-phase induction motor works a bit like a transformer. Current is induced (hence the name of the motor) in the secondary (the squirrel cage on the rotor) by the primary (stator) windings.
If there is a short on the rotor, you get the same problem as a transformer with a shorted turn in the secondary - bug induced currents and overheating.
The secondary (rotor) windings are very simple - often just a single turn of copper per winding, and if you could remove the secondary winding from the rotor intact, it would look (in some motors) like a hamster's wheel, or 'squirrel cage'.
The short was (I guess) between the cage and the magnetic (iron) path through the rotor. You can check for that by just belling between the cage and the iron stampings - there should be no current path.
many thanks CEPTIMUS, its obvious isn't it, thick old me.
  • · Replies 17 ·
  • · Replies 43 ·
11K
