Resistance and Resistivity of tungsten wire
The discussion focuses on calculating the length of a tungsten wire heated from 20.0 to 1320 degrees Celsius, utilizing the resistivity of tungsten at elevated temperatures. The resistivity value of tungsten is established as 5.6x10^-8 ohm-meters, and the temperature coefficient of resistivity is 4.5x10^-3 (C)^-1. Using the formula R = ρL/A, the calculated length of the wire is determined to be approximately 14830 meters based on the initial resistivity, while a subsequent calculation suggests a length of 3.685 meters, indicating a potential misunderstanding of units. The discussion concludes with considerations on the wire's heating capabilities at higher temperatures.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the concept of resistivity and its temperature dependence
  • Knowledge of geometric calculations for cross-sectional area
  • Basic thermodynamics related to temperature and material properties
  • Research the effects of temperature on the resistivity of metals, specifically tungsten
  • Explore advanced calculations involving resistivity in varying units (ohm-cm vs. ohm-m)
  • Learn about the thermal properties of tungsten at high temperatures
  • Investigate practical applications of tungsten wire in high-temperature environments
Students in physics or electrical engineering, materials scientists, and professionals working with high-temperature electrical components will benefit from this discussion.
Unknowned
please check my work someone.
A tungsten wire has a radius of .075mm and is heated from 20.0 to 1320 degrees C. The temperature coefficient of resistivity is 4.5x10^-3 (C)^-1. When 120V is applied across the ends of the hot wire, a current os 1.5A is produced. How long is the wire? Neglect anf effects due to thermal expansion.
OKay we all know R= p x L/A where R is the resistance, p is the proportionality constant known as the resistivity of the material, L is the length, and A is the area.
the book says 5.6x10^-8 is the resistivity for a tungsten wire.
So we solve the equation for L, L= R(A)/p
R= V/I soo 120v/1.5A= 80ohms R= 80ohms
A= 4x3.14xradius^2 so 4x3.14x(.075mm)^2= .071mm^2 A= .071mm^2 or 7.1x10^-5m
T= Tc + 273 20c+(273c)=293K and 1320c+(273c)=1593.15K 1593.15k-293k=1300.12 K
P= (Resistivity)[1+(coefficiant of resistivity)(1300.12K)
p= (5.6x10^-8)[1+(4.5x10^-3)(1300.12)= 3.84x10^-7 p=3.83x10^-7
L=80A(7.1x10^-5m)/(3.83x10^-7ohmsxmeters)=14830m long
is that correct?? anyone??
A= Pi x radius^2 so 3.14x(.075mm)^2= 17.67x10^-9 m^2
T= 1320-20=1300 C
P= (Resistivity)[1+(coefficiant of resistivity)(T)]
p= (56x10^-9)[1+(4.5x10^-3)(1300)] = 383.6x10^-9
L=80(17.67x10^-9)/(383.6x10^-9)=3.685m long
This seems intuitively long to me, so if the resistivity figure is ohm-cm then this seems OK at 3.685cm.
On the other hand, 1320 C is not even a glowing red, is it? So this is not a 180W light bulb, so 3.685m may be OK.
I wonder what it would take to get it up to 3000 - 4000 C like an ordinary light bulb? I guess I will save that for another rainy day. https://www.physicsforums.com/Nexus/editor/smilie.png
  • · Replies 23 ·
  • · Replies 21 ·
12K
