Thread Closed
maximum range (RFID) can function
Share Thread Thread Tools
May28-07, 11:28 AM   #1
I need to know the maximum range in which a radio frequency identification device (RFID) can function. What is it limited by?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
May28-07, 08:17 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
The max range will vary by device.
The manufacturer should be able to supply this info.
May28-07, 08:37 PM   #3
Recognitions:
Retired Staff Staff Emeritus
Eighteen astronomical units.
- Warren
May28-07, 11:19 PM   #4
Recognitions:
Quote by chroot View Post
- Warren
May29-07, 10:55 AM   #5
Mentor
Quote by banerjeerupak View Post
The range is limited by two basic factors. First, there will generally be some limitation on how strong of an RF signal can be used. The limitations may come in the form of government limits (like by the FCC here in the US), in order to limit RF interference with other RF devices in nearby frequency bands. Or the limitations may come in the form of how much power is available for transmission, or how (in)efficient a small transmit antenna may be, etc.
The second factor is the gain of the receive antenna and the sensitivity of the receive circuit, along with the efficiency of the receive processing string. RFID and ISM band low-noise receivers have improved over the past few years, so as NoTime says, you will need to check with several manufacturers of systems to see what kind of range they are claiming.
BTW, in addition to those two basic range-limiting factors, you also have the issue of multi-path interference, which further degrades the transfer of energy. The farther you want to go, the more multipath interference will become a hindrance.
(EDIT: fixed GSM --> ISM)
May29-07, 11:46 AM   #6
plenty of information i see.
i'll have to analyse if before i say anything or ask furhter
Thread Closed
Thread Tools
Similar Threads for: maximum range (RFID) can function
Thread Forum Replies
The physics of RFID systems General Physics 0
small RFID Engineering Systems & Design 4
RFID readers and tags General Engineering 2
RFID Antennas with ferrite Rod Electrical Engineering 0
magnetic fields / RFID Electrical Engineering 1
