| New Reply |
finding an equation of a parabola given three points. |
Share Thread | Thread Tools |
| Sep15-07, 12:49 PM | #1 |
Find an equation of a parabola given three points without a vertex point. 2. Relevant equations y=a(x-h)+k 3. The attempt at a solution The parabola is upside down to I know a is negative. |
| Sep15-07, 12:52 PM | #2 |
Recognitions:
Any thoughts about the problem? What does the general form of the equation of a parabola look like?
| Sep15-07, 01:04 PM | #3 |
y=ax^2+bx+c
| Sep15-07, 01:14 PM | #4 |
I don't know how to find the variables given the three points.
| Sep15-07, 01:25 PM | #5 |
Recognitions:
| Sep15-07, 01:32 PM | #6 |
if you have 3 points and you know the general equation of a parabola what could you make?
| Sep15-07, 02:08 PM | #7 |
the 3 points are: (-2,2), (0,1), (1,-2.5)
I substituted the numbers, giving three equations. 2=4a-2b+c 1=0x^2+0b+C -5/2=a+b+c so c=1 -2b=-4a+1 b=(4a+1)/2 I can't get the numbers to work. This is actually in my calculus book. chapter 1 |
| Sep15-07, 02:22 PM | #8 |
I got the numbers to work. The equation in general form is 2x^2-11/2x+1. How would I convert that to standard form. What is the trick to solving these? I feel like I got lucky to get the answer.
| Sep15-07, 02:35 PM | #9 |
To solve these you will just need to know algebra to solve a system of equations.
if instead of (0,1) you were given some other point you would go ahead and combine 2 equations into 1 hopefully eliminating an x^2 or x or c term, and then working with that one and the remaining equation try to solve for a,b,or c, and using that to solve for the other co-efficients. to get that equation to the standard form you need to complete the square, but you first need to remove the 2 in front of x^2 first. |
| Sep15-07, 04:06 PM | #10 |
The three equations you get are: (-2,2) 4a- 2b+ c= 2 (0, 1) c= 1 (1, -2.5) a+ b+ c= -2.5 Yes, from the second equation, you get c= 1. Putting that into the other two equations, 4a- 2b= 1 and a+ b= -3.5. Can you solve those two equations for a and b? Once you do have the correct equation, if by "standard form" you mean y= a(x- h)2+ k, you get that form by completing the square. |
| Sep15-07, 05:28 PM | #11 |
I had 3 equations.
-2=4a+2b+c -5/2=a+b+c 1=0+0+c |
| Sep15-07, 05:34 PM | #12 |
the solutions I got were 2, -11/2, and 1. They worked in all 3 equations.
| Sep15-07, 05:43 PM | #13 |
Every time I do this problem, I get different answers. I have always had trouble with these. I can handle trig easily compared to these problems. I am so frustrated.
| Sep15-07, 05:51 PM | #14 |
I think I switched the signs around. Now I get
2=4a-2b+c 1=0+0+c -5/2=a+b+c and got a=-1 b=-5/2 c=1 Does that sound better? |
| Sep15-07, 06:50 PM | #15 |
Recognitions:
| Aug12-11, 02:18 PM | #16 |
If I am given the points (-6; -2), (4; -2) and (1; -8) with the equation y = 2 x^2 + bx + c, CAN I use any of the two points two simultaneously solve for b and c?
By the way I tried and get different values with different points. The only reasonable solution is if I solve the problem using the fact that x = -1 is an axis of symmetry and then use the general equation y = 2(x + 1)^2 + q. Then use the point (1; -8) to find q. Rewriting the equation gives b = 4 and c = -14. Why don't I get the same when I solve simultaneously? |
| Aug12-11, 04:05 PM | #17 |
Mentor
The three points are not on the same parabola -- at least they're not consistent with being on the same parabola if it's of the form: y = 2 x2 + b x + c .
| New Reply |
| Thread Tools | |
Similar Threads for: finding an equation of a parabola given three points.
| Find the equation for a parabola given 3 points | Precalculus Mathematics Homework | 10 | ||
| Finding a Parabola using three points, no equations | Linear & Abstract Algebra | 2 | ||
| Finding the equation of a parabola | General Math | 3 | ||
| finding equation of a parabola? Help | Precalculus Mathematics Homework | 4 | ||
| Finding the equation of a parabola | Precalculus Mathematics Homework | 3 | ||
