Calculating the index of refraction of a gas
The discussion revolves around calculating the index of refraction of a gas using an interferometer setup. The problem involves a glass container with a specific depth and the observation of dark fringes as a gas fills the cavity.
  • Participants explore the relationship between the wavelength of light in different media and the optical path length. Questions arise regarding how the cavity depth influences the number of wavelengths and the resulting fringe pattern.
Participants are actively engaging with the problem, with some providing insights into the relationship between wavelength, index of refraction, and cavity depth. There is a focus on understanding how these factors contribute to the observed dark fringes, but no consensus or resolution has been reached yet.
Participants note the specific parameters of the problem, including the wavelength of light and the number of dark fringes observed, while questioning how these relate to the cavity depth and the index of refraction.
mrbling
Question: One of the beams of an interferometer, as seen in the figure below, passes through a small glass container containing a cavity D = 1.40 cm deep.
When a gas is allowed to slowly fill the container, a total of 230 dark fringes are counted to move past a reference line. The light used has a wavelength of 600 nm. Calculate the index of refraction of the gas, assuming that the interferometer is in vacuum.
I'm not even sure where to start with this question.. any help?
The wavelength of light in a medium is lambda/n, so the total number of wavelengths contained in the region with the gas gets bigger. IOW, its optical path length gets longer. This is what causes the fringes.
swansont,
thanks for your response..
from the information given, I know that:
dark bands occur at: 2t=m lambda (where t is thickness)
m(order) =230
lambda(in vacuum) = 600nm
from what you mentioned, the light going through the gas chamber will have change wavelengths.. and that wavelength is proportional to the index of refraction (via: lambda(in gas) = lambda(in air)/n)
so my question is: how does the 1.4cm cavity figure into things?
Thanks
mrbling said:
swansont,
Thanks
How many wavelengths fit into the cavity before and after the gas is introduced? That's the reason for the fringes, so the length has to be known.
  • · Replies 24 ·
11K
