How can you find two different values for sin^-1(0.750)?
  • Thread starter Thread starter ND3G
The discussion revolves around the calculation of the inverse sine function, specifically finding two different angles for sin-1(0.750). The original poster notes a discrepancy between their calculated angle and a value provided in a textbook, prompting questions about the interpretation of inverse trigonometric functions in a physical context.
  • Participants explore the concept of inverse sine and its multiple solutions, questioning how to determine the appropriate angle based on the physical situation. There is discussion about the unit circle and the implications of angle directionality in relation to vectors.
The conversation has led to various interpretations of the problem, with some participants offering insights into the nature of inverse trigonometric functions and the importance of context in selecting the correct angle. There is no explicit consensus, but productive guidance has been shared regarding the relationship between angles and their sine values.
Participants note that calculators provide outputs within specific ranges for inverse trigonometric functions, which may not align with the physical requirements of a given problem. This highlights the need for careful consideration of the problem's context when interpreting results.
ND3G
I am working on a statics question and one of the angles is sin^-1(0.750) which I calculate as 48.6 degrees though the book gives 131.41 degrees
If I calculate sin(48.6) it equals 0.750
If I calculate sin(131.41) it equals 0.750
Clearly there is some relation or rule that I am unaware of. How do I ensure that I find the proper angle?
Just draw the unit circle and joggle a bit then all becomes clear.
sin^1(0.75) means "what angle gives y = 0.75" if you do the unit circle. You'll see that there is two angles in the range 0 - 360 degree that gives you that value.
Which is correct depends on what the problem is, what physical situation it is and so on.
sin x = a has infinitely many solutions for x.
If you're working on a problem and expect a unique answer, then you'll have to find some other constraint on x.
Ok, I figured it out. Because of the direction of the vector it is not 0 degrees + 48.6 degrees but 180 degrees - 48.6 degrees which equals 131.4 degrees
You realize that you said nothing at all about vectors in your original post. And even now, we do not know WHY the direction is "180 degrees- 48.6 degrees"!
Your calculator cannot help you with interpreting the output in relation with the problem you are working on. The inverse trig functions on a calculator will only give output in the ranges
arcsin or arctan: -90º to +90º (not quite 90º, of course, for arctan)
arccos: 0º to 180º .
In order to define these as functions, it is necessary to have restricted ranges on
y=f(x) and the calculator is programmed to follow these definitions (this is why the inverse trig functions are sometimes identified as Sin^{-1}, Cos^{-1}, etc., rather than using lower-case).
As you note that the positive sine value is associated with two angles (in the first and second quadrants), it is important to have a picture in mind for the physical situation in order to decide which angle is appropriate to the solution. (I particularly warn engineering students about this all the time: you have to know what the result should look like because the calculator can't.)
Thanks
