Hovercraft levitation - simple ideas needed
  • Context: High School
  • Thread starter Thread starter aychihuahua99
    Ideas Levitation
The discussion revolves around creating a miniature hovercraft, focusing on practical ideas and materials suitable for a school project. Participants share various methods and materials for building hovercrafts, emphasizing simplicity and feasibility for a 7th-grade project.
  • Homework-related
  • One participant requests basic materials for building a hovercraft, indicating a lack of prior knowledge in physics and math.
  • Another suggests using a dust-buster, cardboard or balsa wood, and wind-proof cloth as potential materials for construction.
  • A participant shares their experience of making hovercrafts using foam meat trays, a nine-volt battery, and computer fans.
  • Another idea involves using a CD, a thread spool, and a balloon to create a simple hovercraft, with suggestions for using a larger record for better performance.
  • One participant proposes a more ambitious idea of using a gas-powered leaf blower to create a personal hovercraft, although they express doubts about its practicality.
  • A later reply humorously notes the age of the thread, suggesting the original poster may have completed their project long ago.
Participants generally agree on the feasibility of building a hovercraft with simple materials, but there are multiple competing ideas regarding the best approach and materials to use. The discussion remains unresolved as no single method is endorsed over others.
Some suggestions depend on specific materials and tools that may not be universally available, and the effectiveness of proposed designs may vary based on construction quality and available resources.
aychihuahua99
Okay, I know there are old posts, but I can't understand a word cause I'm in 7th grade. So, I need to make a miniature hovercraft that can actually levitate. Price isn't a problem, so can anyone give me the basic materials and where to get them? I'm not what you call a physics or math genius, so bear with me.
You could probably build one with a dust-buster, a piece of cardboard or balsa wood, and some wind-proof cloth (like a windbreaker).
If price really isn't a problem then you can buy a remote controlled one: https://www.amazon.com/dp/B000WDWQFM/?tag=pfamazon01-20
Ok, thanks, I'll look it up.
Ok, I saw the remote controlled one, but I need to build one, not buy one. I want to get a good grade on the this project, do you have any ideas on how to make one?
And also, I need to do this in-class, I think, so a little 5x11 inch one or something is about it
ive made little hovercrafts out of foam meat trays a nine volt and two motors with computer fans on them...Pretty cool! interested?
You can make a quick and dirty one with a CD, a small thread spool glued to the CD so the holes match and a balloon attached to the spool (or some other way to attach the balloon to the CD hole), you might have to make the CD hole a little smaller. Blow up the balloon through the CD hole and set it on the floor and you have a hovercraft for as long as the air in the balloon lasts. It will work better with a 33rpm record and a bigger balloon if you can find one. I did this as a kid with a record and it works. If you can find a small enough and light enough air pump a record will give you a nice base to build on, lots of surface area. Just try to get it balanced as good as possible when you build it. A little creative covering and you have a flying saucer. You will have to give it a push unless you put in some kind of side thrust on top but it will go a long way with a push because it is almost frictionless.
I was looking at a gas powered backpack leaf blower the other day and started to think about running the air to some wide bottom shoes to make a personal type of hovercraft (more like frictionless shoes than hovercraft) but I don't think it would put out enough air pressure to have reasonably small shoes. The larger the surface area underneath, the less air pressure is required.
edit: just noticed how old this thread is, the kid could be in college now lol
haha thanks guys, but I'm already done with the project now
  • · Replies 32 ·
  • · Replies 45 ·
