Prove that the cuberoot of 2 is irrational
  • Thread starter Thread starter Goldenwind
    Irrational
The discussion revolves around proving that the cube root of 2 is irrational. Participants explore the implications of assuming it is rational and the resulting contradictions that arise from this assumption.
  • Participants discuss starting with the assumption that the cube root of 2 can be expressed as a fraction of integers in lowest terms. They explore the implications of this assumption, particularly focusing on the parity of integers involved.
There is an ongoing exploration of the relationships between the integers a and b, particularly regarding their evenness and the implications for the proof. Some participants express confusion about the reasoning, while others provide clarifications and suggest connections to the proof for the square root of 2.
Participants note the constraints of using definitions of integers and the requirement that the fraction be in lowest terms. There is also mention of the challenge of applying similar reasoning from the square root proof to the cube root scenario.
Goldenwind
[SOLVED] Prove that the cuberoot of 2 is irrational
Assume it is rational, and find a contradiction.
2^(1/3) = a/b, where a, b are integers, where a/b is in lowest terms, and where b != 0.
2 = a^3 / b^3
2b^3 = a^3
Aaaand stuck.
Can someone give me a little push?
It works just like the square root proof. What happens if a is not divisible by 2?
To be completely honest, neither of your answers really make sense to me :(
I mean, I'm sure they're completely valid and correct answers, but I'm having trouble grasping what you're getting at.
Can someone elaborate a little? I realize it has something to do with the definitions of a and b (Being integers, lowest terms, and b != 0), but I don't see what.
And NateTG, I have the squareroot proof in my book, in front of me... but it uses the fact that a^2 and b^2 = even. I can't use that fact here, as a^3 will be of the same polarity as a, and b^3 the same polarity as b. I can't rely on it being even, nor odd.
since 2b^3 = a^3 don't you know that a^3 is even? therefore making a even?
then a = 2c for some integer c, and subbing back in you get 2b^3=(2c)^3=8c^3?
does this help?
does this help?
If a^3 = 6, then a = cuberoot(6), which in theory would be irrational (However proving this would just be another huge circle).
If a^3 is even, why is a even?
Ooohh... 'cause a has to be an integer...
Yeah, I think I see now.
And then because a and b are both even, they're both divisible by 2, which breaks the hypothesis of "lowest common terms".
Yes?
If a is odd what's a^3, odd or even?
Yes?
Yeah, which is the same proof as for square root 2.
Yep, solved the problem now. Wanna know what was confusing me? For some reason, I thought that a^2 = Even, regardless of value of a. But then I sat there and thought... 3^2=9...wtf?
Yeah... sorry for the stupid questions, and thanks for your help everyone :)
With your help, I've not only completed this question, but blasted straight through the next one ^^;
