Resolving Distant Objects question
  • Thread starter Thread starter fatkat444
The discussion focuses on resolving distant objects using a telescope with a 2.0 cm aperture. The relevant equation for calculating the maximum wavelength (lambda) for resolution is sin(theta) = 1.22 x lambda/D. The user initially calculated lambda as 0.492 nm but later corrected it to 492 nm after realizing a unit conversion error. The final resolution wavelength is confirmed to be 492 nm.
  • Understanding of basic optics principles
  • Familiarity with the concept of angular separation
  • Knowledge of unit conversions, specifically between meters and nanometers
  • Proficiency in using the equation for diffraction limit in telescopes
  • Study the principles of diffraction and resolution in optical systems
  • Learn about the Rayleigh criterion for resolving power in telescopes
  • Explore the effects of aperture size on image resolution
  • Investigate advanced telescope designs and their resolving capabilities
Astronomy students, optical engineers, and anyone interested in the principles of telescope design and resolution of distant objects.
fatkat444
[SOLVED] Resolving Distant Objects question
Consider a telescope with a small circular aperture of diameter 2.0 centimeters.
If two point sources of light are being imaged by this telescope, what is the maximum wavelength (lambda) at which the two can be resolved if their angular separation is 3.0 x 10^-5 radians?
Relevant equation - sin(theta) = 1.22 x lambda/D
I get - Dsin(theta)/1.22 = lambda
0.02 x sin(3.0 x 10^-5)/1.22 = lambda
= 4.92 x 10^-7
therefore lambda = 0.492 nm
It doesn't seem correct. Any help would be very appreciated.
You're correct its just you have the units confused. It will be 492nm not 0.492. Remember a nanometer is 1 billionth of a meter. So one nanometer is 1x10-9 m.
yeah i just figured it out and was coming back to post as you replied, thanks anyway though.
